Dinette tables in booths
NewTTcamper
We are now looking for a TT of our dreams. We own a Lance camper. I noticed that some dinette tables have two legs. But even so, the tabes still rock really bad. Worse than in our Lance. Does anyone have a suggestion to lessen the table movement? It seems a longer receiver for the bottom of the leg would help solve this issue. Why haven't manufacturers figured this out?
13 REPLIES 13
wmoses
myredracer wrote:
wmoses wrote:
How much wobble is too much? ALL designs will have wobble to some degree, ...
Afraid I have to disagree on "all". Our double Lance legs do not have any discernible movement plus we have a factory solid wood table that does not move or flex. The Lance flanges and leg are machined with a tight tolerance. Maybe with a lot of force you'd see some movement, but by that point, the floor would be flexing.
Note that I said "to some degree" - that justifies the use of "all". I also suggested that one man'w wobble might be imperceptible to another. Unless you have a table with 4 legs at the 4 corners, and have a robust grillage all across the table top underneath, there will be movement. ๐Ÿ˜„
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Opie431
Ours has a small thingy that sticks out from the wall. The table rests on that and does not wiggle.If yours does not have one it should be easy to make something to work the same way.
martipr
Replaced mine with these: http://www.factoryrvsurplus.com/products.php?product_id=1965 Picture shows white but they are actually black. Find also on ebay: http://www.ebay.com/itm/29-5-FOLDING-TABLE-LEG-Cream-or-Tan-color-rv-camper-Hengs-HG-FL295-/22147662.... We really love them. Easy up, easy down, very sturdy and solid, table can be moved about, even taken outside.
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
myredracer
wmoses wrote:
How much wobble is too much? ALL designs will have wobble to some degree, and some call wobble a bit of a deflection on one edge when you push down on it with some degree of force. That force is proportional to the movement and is something that I believe we all have to live with.
Afraid I have to disagree on "all". Our double Lance legs do not have any discernible movement plus we have a factory solid wood table that does not move or flex. The Lance flanges and leg are machined with a tight tolerance. Maybe with a lot of force you'd see some movement, but by that point, the floor would be flexing. If you want a really solid table setup, go with the Lance legs.
oughtsix
The table in my trailer has folding scissor legs. We frequently take it outside and use it around the campfire. It is actually does not wobble much inside or outside.
2006 Duramax Crew Cab Long Bed pickup.
2007 Coachman Captiva 265EX trailer.
_tiredTeacher
X2
Our dinette area is carpeted so the table legs sit on carpet. Quite a bit of wobble IF you "push down on it with some degree of force," so we don't.
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
wmoses
Regards,
Wayne
_
Doug33
Ours connects to the wall via a hinge, which you can remove to create the bed.
2014 Keystone Bullet 281BHS
2002 Chevy Avalanche 5.3L 4x4
Equalizer hitch
Nights spent camping in 2015: 25
Next trip: mid-April 2016?
myredracer
Those standard wobbly legs should be banned. They look nice on the dealer's lot until they get used in real life...
The solution in our KZ was to install legs from, you guessed it, Lance. Now 100% rock solid plus they look great. One benefit to these is that you don't end up with holes in the floor to deal with. Lance has the nicest looking legs around. :W
Another option is to install a wall bracket and folding leg. I did this on our first TT. I installed laminate flooring in it and didn't have holes in the floor to fix. If you want to use this option, you can probably find a piece of sheet flooring from under a cabinet somewhere and get a professional floor layer to install patch pieces that are seam welded/glued. Some dealers can also do this type of repair.
NanciL
Mine are rock solid in my Pioneer. We take the top off on occasion for one thing or another and when we put it back it is still solid.
Jack L
Jack & Nanci
NewTTcamper
Yes Lance figured it out years ago. That's why I have an issue with the TT tables. We did try to push down on tablles in many TTs to snug it up, but still wobbled more than my 96 Lance. We were in many high end RVs. I guess that's the nature of the beast. We're hoping to somehow modify.
FrankShore
Lance has figured it out. The tables don't wobble at all.
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
MFL
Nomad II
Nomad II
My last two FWs have the double post table, and both rock solid. Maybe some brands are different, but if pushed down all the way, a new model, should have a solid table.
Jerry
