Double axle wheels not flush
jamesp
The wheels on the left and right side of my Evo travel trailer or not flush. There is at least a 2 inch difference from the wall of the front wheel and the wall of the rear wheel on the left and right side. Is this normal? I purchased my TT 3 days ago.
9 REPLIES 9
hohenwald48
I think on most forums it usually takes several days to get a single response to a question. Of course on here it usually only takes a few minutes to get several responses and new folks don't expect that. ๐Ÿ™‚
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Old-Biscuit
Hello.........
Join, ask one question, get answers/suggestions/questions and no response back.
Come on that's not showing any manners
rbpru
Our dealer warned us the wheels will sit at odd angles when turning etc. But as mention when pulled straight they are aligned.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
hohenwald48
As Old Biscuit said, it may be just fine if you parked the trailer by putting it in a twist from a turn just prior to parking. If you have pulled it straight forward for 10 or so feet and still have the condition you may have a problem. A picture would be nice if you can post one.
RoyF
Agree with Old Biscuit that you need a shop that deals with truck frames and axles; they have the ability to check the tire's camber (degree of tilt) and correct it if necessary.
Such a shops may not be listed under any of the obvious key words, "frame", "axle", "trailer". In my area the only such shop is listed under "truck repair and service". My RV dealer referred me to them when the fifth-wheel had uneven tire wear.
4X4Dodger
I am not sure I understand exactly what you are saying. Are you saying that the rear axle is "wider" than the front? As in it has a wider track?
or is this just an individual wheel issue. After reading your post carefully I am not sure.
Can you elaborate?
scbwr
Chuck_thehammer wrote:
if used.. do as Mr. Old-Biscuit said..
New.. return to dealer and have them prove correct or NOT.
And make sure you have a written record of the service call at the dealership (if new) so you can prove that you have reported a possible defect if you need to at a future date.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Chuck_thehammer
Old-Biscuit
Are you looking at this caddywhompus 'out of plumb' condition just after parking trailer and having to maneuver it/tight backing etc.
OR looking at this condition after trailer has been pulled straight forward for several feet.
Tight turning/maneuvering with double axle trailer WILL cause front/rear tires to be off set.
Now if offset is there after trailer has been towed straight line......then you need to locate a trailer shop/big rig shop (not some RV Repair or CW) that can do trailer alignments and re-arch axle tube if necessary.
Otherwise you will have to be dealing with blow outs/worn tires/lousy tracking while towing trailer.
