DRW vs SRW Trucks
snowcrustracer
Hi folks,
My DH and I are thinking about buying a new truck and are having some trouble deciding between a dual rear wheel truck and a single wheel truck.
Right now we have limited time off from the rat race and usually just stay in campgrounds so I'm not sure those habits will change when we retire.
The campers we seem to have chosen are the bigger models such as the Host triple slide and the Northern Lite 10.2EXRR. These campers probably would be more comfortable driving with a DRW.
Can we never travel fire roads and trails out in Utah or Colorado with the DRW? Will we be stuck only in campgrounds.
Any thoughts folks could add to the plus or minus list would be very helpful.
Thanks,
Snow
2000 Toyota Tundra & 2007 FWC Eagle (SOLD)
2016 GMC Sierra 3500 DRW & 2017 Northern Lite 10-2 EXRR
38 REPLIES 38
Glacier_D
I drive a dually brush engine for a private contractor out of Boise during fire season and that dually will go just about anywhere. As others have said the camper will be your limiting factor.
2011 Dodge Ram 3500 4X4 Crew Cab/LB, Rancho RS9000XL, Stable Loads, Superhitch and FastGuns. 2009 Eagle Cap 1050, Hickory interior with on-board generator, A/C and Honda EU2000
insp1505
The height and length of the camper will limit where you can go way more than the DRW ever will. Have a check between the duals before getting back on the highway and you'll be fine. I've never picked up a rock. . . yet!
Memorial weekend
Little Lost River
Merriam Lake
snowcrustracer
Thanks you all have been very helpful. I really feel we will be happier with the DRW truck but have been stressing about maybe being to big to explore those out of the way places.
jimh406
snowcrustracer wrote:
What about rocks between the back tires...where do you draw the line when exploring the trails?
I haven't had an issue yet, but I've only had my DRW 2 years. I do have 19.5s which are very tough. My line is will the camper clear. That being said, I'm not searching for mud to go through! I did buy very aggressive Hankook DH01s.
Vinsil
Huge camper...DRW. You can still get off the pavement with them. You draw the line at your knowledge and comfort level with how "offroad" you get. Me...if it is getting soft and deep, time to head back.
My next truck will be a DRW. You can see the mods I needed for my srw and I have a "small" non slide TC.
2017 Ford F-350, crewcab, 4x4, 6.7 diesel.
2016 Thunderjet Luxor 21' limited edition, Yamaha powered.
2016 Wolf Creek 840-SOLD, Arctic Fox 990 ordered.
snowcrustracer
jimh425 wrote:
You can easily drive fire roads with a DRW. Other than narrow roads that might be too narrow for the extra tires, a DRW should be fine. Keep in mind that fire roads are generally made for bigger trucks and of course, logging trucks are even larger!
The biggest limiting factor is probably height and weight of camper which will be the same whether you have the SRW or DRW.
That's a very good point about logging trucks and fire truck paving the way on these roads.
BB_TX
Regardless of the specific trailer you like, you must consider the loaded pin weight of that trailer. Then you must look at the payload capacity of the truck(s) that interest you. That will determine whether you "need" a DRW or not. Need is different than want. If the numbers dictate it, then buy a DRW. If the numbers don't require a DWR, then it becomes a personal choice. There are those who feel much better driving a DRW no matter the trailer weight in spite of some minor every day driving inconveniences. Then there are those who prefer an SRW and will stick with that, weight permitting. If the weight numbers match up, stability is not a problem with an SRW. Only you can decide.
mr70ss
Just my $.02.. I had a SRW 2500 and it worked fine (w/ and 8'6" w/slide) camper was around 2800 dry. I just purchased a new 9' 10" and it's around 3500 dry. I looked into using my SRW, but i would have had to swap out the wheels and tires for 19.5" + other mods... all in all i upgraded to a DRW. If you are looking at large multi slide campers you will need a DRW.
'13 Chevy 3500HD, DRW, Firestone Bags w/ onboard air.
'16 Adventurer 910FBS, Torklift tiedowns, and XL Spring loads.
jimh406
