Dually Conversion
The_Works
I have a 2011 Chevy 3500HD diesel, crew cab, long box, single rear wheel (SRW), 18,500 towing capabilities. I have seen conversion kits to convert my SRW to a dually, has anyone done this this? If so, are you happen with the results? Reasons for my thinking is, I like my truck, its paid for, I bought it new and have had it serviced when necessary and it runs great. I bought a 41 ft Heartland Big Horn 3750FL, 16K gvwr and I'm pushing the load capabilities for the SRW tires. I don't need to increase the load capabilities of the truck but I want to feel a little more secure with the camper load distribution on four dually tires vs. two. Any problems with this thinking?
Also, how can one weight the truck and camper to determine the pin weight? Thanks for your positive input and comments.
21 REPLIES 21
Hank85713
check out arrow wheels. They sell dually conversions, I thought about it but I dont tow heavy enough to need them.
jerem0621
Go for it...should cost about 3-4k to do it right with new tires and wheels and off set hubs...
The posters above are correct...the sticker will not change automagically but you will have drastically increased the capability of the truck and for Your peace of mind and your understanding of the trucks new capability.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
BenK
You'd spend more having it certified with a new GVWR than just going out
and buying a dually...
Going to commercial class tires/wheels will gain more tire capacity, but the
RGAWR and GVWR will still be the same...and...have to go through above to re-certify
In going to a dually conversion using commercial class tires will gain you
higher tire capacity and the biggie...wider track. Along with 8 sidewalls
rated commercial class
Agree...your front axle a spindle will need to changed out to the right
offset if the wheels are NOT dually offset now
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
newman_fulltime
you have to convert the front as well for it to track correctly down the road
blt2ski
Moderator
Moderator
The dually from the factory HAS the offset hub on it. so how is adding this to a non factory dually to be an issue?
With this in mind, a set of 225-70-19.5's would net you 9000 lbs of tire capacity, 245-70-19.5 upwards of 11K lbs of tires per axel. The 225's would be no diam difference if you already have 265's on the truck. 245;s would be about 1-1.5" more in diam, reducing your overall axel ratio to about a 3.55. Not my first choice, as these rigs are geared a bit too tall for steeper hill ie 20+% grades for starting power.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
Golden_HVAC
You might consider super single tires with a much higher than stock weight rating. Look at a place like http://www.ricksontruckwheels.com/index.php
They sell 19.5" rims with a 4,500 pound weight rating, and you can buy tires locally to avoid shipping fees.
If you have 4 wheel drive, then replacing all the rims is required to keep the same outside tire diameter. If you have 2 WD, you can just replace the rear two, and keep the others for the front axle or a spare. Sell the tires once they are nearly worn out on Craigslist to recoup some of your investment in the larger rims. .
Aftermarket conversions usually require a hub being installed to offset the front rim by 4" outward, to fit the dually shape rim on it. And the same type of adapter on the rear axle. Both are somewhat 'weak links' that I would rather not have on a 10,000 pound truck!
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
donn0128
This will still not alter the GVWR sticker on your drivers door post. If your going to go this route, I would suggest you find a donor dually to take the bed, rear axle assembly from. Remember duallies also have different studs, longer to accompdate the dual wheels. Of course, once you have the bed painted to match the cab, and the donor parts your total cost would likely exceed the cost to trade plus cash for a real dually
