Dually tire valve extenders that make it easy
Jgwoods
I'm beating my head against the wall trying to set up my f-350 so I can easily reach the tire valves for inflate/deflate.
I have old knees and can't be crawling around trying to get at the tire valves.
Does anybody have a good set up? I don't mind modifying the plastic hubs, whatever it takes.
I am running the aluminum 17" wheels that are stock on the 2013 Lariat.
Any help is appreciated.
22 REPLIES 22
Jgwoods
Frustrating but I cannot reach any tire man links. Is it a tire store chain?
I contacted the Crossfire folks and am waiting for a certain contact there to return Monday so we can talk about whether it can be aired down or not.
If anyone can post a picture of their easy to use set up I sure would like to see it.
Many thanks again,
Joe
RoadAbode
Have had my set since 2006 from the Tire Man: "Tire Man Valves" May 2006 Post
trander wrote:
IAMICHABOD wrote:
What is needed is a extended valve stem that will let you quickly check your tire pressure. They add no extra weight like the Extenders would and balancing is no problem.
The best on the market,that are the original,are Tire Man any others are Knock offs and of inferior quality.
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help.
+1 on this kit! It works great!
The RoadAbode Crew
Mike ~ Amy ~ Kimberly ~ Emily ~ and Molly the pup
RoadAbode Blog
trander
2003 Lance 1121, 2006 Dodge 3500 quad cab Laramie 4X4, auto, 4.10
Jgwoods
fpoole wrote:
I'm not sure if this is what you're looking for, but they do have a post here? on "Valve Extenders"
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27662194/gotomsg/27663426.cfm#27663426http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27662194/gotomsg/27663426.cfm#27663426
and by setup.
http://yourtireshopsupply.com/category/796/dually-valve-kitshttp://yourtireshopsupply.com/category/796/dually-valve-kits
hope that helps..
For some unknown reason the links are dead ends for me so I can't access any information.
The other suggested link went to a site with equipment for steels wheels only and I have aluminum wheels.
Thanks for your responses but I am still searching.
Any more suggestions?
many thanks,
Joe
1971amerigo
I don't believe a crossfire system will let you deflate your tires.
They have a check valve to prevent accidental deflation.
lj2654
get a crossfire system and you will be set!
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
IAMICHABOD
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
fpoole
and by setup.
hope that helps..
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
