โOct-27-2013 05:01 PM
โNov-02-2013 11:38 AM
โOct-31-2013 08:41 PM
Turtle n Peeps wrote:Sounds like the perfect time to switch to manual mode for gear selection!
Without writing a book, in my case, it conserves too much energy. IOW's, when I come down a mountain I may tap my brakes several times and each time I do it downshifts. Then I have to add fuel to keep up with the turtles. Then it downshifts again and I add more fuel...................Downshift, fuel, downshift, fuel, downshift, fuel, downshift, fuel........That adds up.
โOct-30-2013 01:17 PM
kaydeejay wrote:fly-boy wrote:Please explain why you think that. Higher shift points does not necessarily equate to worse fuel economy if the power being transferred to the road is the same. The engine may be revving higher but at a lower throttle opening.
I would not bother with T/H for a 4400 pound trailer. All it is going to do is decrease your fuel economy.
I have noticed NO difference between T/H on or off as far as economy is concerned.
In fact theoretically economy could be a tad better due to the lack of heat lost in the torque converter.
โOct-30-2013 09:44 AM
โOct-30-2013 09:28 AM
โOct-30-2013 09:18 AM
โOct-29-2013 09:42 AM
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
โOct-29-2013 09:33 AM
โOct-29-2013 07:32 AM
timdan94 wrote:sayoung wrote:salem wrote:
I put mine in TH when I'm sitting in my driveway getting ready to take off and leave it in till I unhook.
Same here on my 12 but I am towing close to 14k.
Exhaust brake only works when in tow/haul.
exhaust brake does work without tow haul activated. its just not as aggressive. I use the exhaust brake in everyday driving.
โOct-28-2013 03:04 PM
โOct-28-2013 10:38 AM
โOct-28-2013 07:37 AM
โOct-28-2013 05:54 AM
sayoung wrote:same here but I am sitting at 20k combined while towing, and yes I do have a exhaust brake via..EFI livesalem wrote:
โOct-27-2013 10:38 PM
nevadanick wrote:
I pull quite a bit more than that and only use tow haul when i get in mountains.
