Ecoboost engine question
Bmach
With the Eco doing so well and loved by many and bragged about by Ford. Why is it not offered in the F250 ?
I love mine but I'm curious.
92 REPLIES 92
pronstar
Real HD trucks ("18 wheelers") use girly 6-cylinder engines LOL
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
jus2shy
goducks10 wrote:
It just boils down to the fact that real men drive HD trucks and no real man wants a 6cy motor in his manly truck:)
Hey, I have a 6-cylinder in my HD :P. And I think many RAM/Dodge owners consider themselves real men :B (Unless you're a hard died-in-wool GM or Ford fan LOL).
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
goducks10
hone_eagle
I like to think of the IC engine as a air pump-a 3.5 becomes a 7.0 if you force twice as much air in ,add the calories of gasoline ,burn completely = work at crank.
elemental chemistry
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
Engineer9860
The whole reason for the turbos on the Ecoboost engine are to fool a small displacement engine into thinking it is a large displacement engine. Same for turbo diesels.
The Ecoboost's low speed efficiency comes from its small displacement not its turbos.
You can never defy the laws of nature. Fuel energy is converted to heat. Heat is converted to horsepower. How an engine does this specifies how fuel efficient it will be. At low horsepower demand situations a small displacement engine will be more efficient because fuel is not needed merely to rotate large engine parts. In low horsepower demand situations a large displacement engine loses efficiency because energy is needed just to move it's more, and larger parts.
In high horse power demand situations all of the above no longer applies because both engines are working at capacity. In low horsepower demand situations the small displacement engine will focus a smaller percentage of the fuel burned on actually turning the engine parts. In the high horsepower demand situation a greater percentage of the work the engine is doing goes to the actual work being performed.
There is no free lunch. At the end of the day a certain level of fuel will still be needed to move a heavy brick through the air while its tires are trying to resist rolling. This is constant no matter what is under the hood.
In Memoriam: Liberty Belle
Wes_Tausend
Turtle n Peeps wrote:
Wes Tausend wrote:
On the other hand, I believe that a turboed engine is slightly more efficient than a NA (normally aspirated) motor for the same hp and/or equivalent displacement. The reasoning is that the end exhaust is slightly cooler on the turbo, meaning it derives more power (more is used to do work) out of the same fuel that must be equally burned to provide identical propulsion of a pair of trucks. One of the pair is assumed to be turboed, the other NA in this imaginary test.
You would be incorrect. BSFC is quite a bit higher with a supercharged engine.
Hi, Turtle,
We've had this discussion before although I always welcome your posts and comments. I know you've had a lot of experience with race engines.
I believe you, and your author are out of context about this type turbo application. You will note that the sole reason given by your source to the contrary is the air/fuel mix must be rich to prevent detonation.
QUOTE:
"Well, we can get a range of BSFCs for engines. For example, in our last post I used 0.65 as a safe number for a turbocharged engine. Most turboโ€™d engines run between 0.6 and 0.65 BSFC while supercharged cars have a BSFC between 0.55 and 0.6, and naturally aspirated engines use only 0.45 to 0.5 Lbs/Hp*Hr. These are only approximations, but you can clearly see the difference between naturally aspirated engines and turbocharged engines. Turbocharged engines usually require more fuel to keep detonation at bay due to the increased temperature and pressure of the intake air".
I think the BSFC efficiency is worthy of further debate in the overall 3.5L EB design. Like I said, I'd like to try it. From what I've read here, there are some indications that the towing efficiency is up to 1 mpg better using a turbo rather than larger NA displacement in this case.
That the turbo air/fuel mix must be rich to prevent detonation certainly usually true of non-intercooled carburation or indirect gasoline fuel injection. However, even in these cases, water/alcohol injection can be used to almost entirely mitigate the detonation and both rich mix and water/alcohol are only used best during high boost. The water/alcohol can also be used in turboed diesel engines to reduce exhaust gas temps. During racing, alternate EGT cooling can also be achieved by cold nitrous or, I believe, generous overfueling.
The one thing that is a game changer for Ford is the use of direct injection (DI), and under-piston oil spray cooling along with good intercooling. The combustion air/fuel mix can be run closer to stoic 14.7:1 because under conditions of high boost, the injection(s) can be delayed to any point beyond TDC (after top dead center). The pure air mix cannot detonate early, or pre-ignite, without the fuel being added. EGR can also be added before fuel, further reducing combustion temps. After TDC, the chance of detonation is less of a serious problem. This is nearly the sole reason DI is used in high tune diesel engines also.
None of this gasoline technology was commonly available to your author (good article by the way) on turboed race engines when he wrote the piece. In addition, he is basically just parroting earlier "safe" tech understandings without offering much on, what would be considered, exotic modification for efficiency. Ford has done something different here. Never before has any manufacturer actually combined all the previous knowledge into actual production, certainly not the last great turbo app OEM offering, the stupendous 3.8L Buick Grand National.
One of the reasons straight supercharging can be more efficient than a turbo is that the boost level, therefore the "planned" fuel curve, is well predetermined. Turbos are less predictable at any given RPM and only a very fast control system could possibly adjust parameters quick enough to prevent detonation. Fords computer is that good, it's a new game.
Which brings us finally to the question of whether a cooler downtube exhaust gas has really raised efficiency. The exhaust gas is hotter before it enters the turbo (even if we have to best wrap it with insulation ala Corvair). There is no doubt that more heat has been subtracted from the combustion process. But has it actually turned more heat into better torque propulsion? Or has the precious heat escaped by radiation from an extremely hot turbo feed, or intercooler loss? I don't really know. If the additional subtracted heat has been used to reduce intake pumping losses, then yes, the engine has used the fuel more efficiently to achieve the improved end torque we are looking for.
I think my Excursion might roll at low 3.5L boost cheaper than the V-10 internal losses at moderate highway speeds. I wouldn't expect a lot of difference. But just maybe. That is really the crux of this thread.
Wes
Days spent camping are not subtracted from one's total.
- 2019 Leprechaun 311FS Class C
- Linda, Wes and Quincy the Standard Brown Poodle
jus2shy
I personally think that for ecoboost motors to return the fuel economy they tout, they must stay out of boost. My personal experience was with my 07 saturn sky redline. That car was rated at 29mpg freeway. However, if you could stay out of boost, I was able to eek out 34mpg. If you put the ecoboost in a heavier rig like the F250 and higher, the heavier chassis and possibly increased drag of components and aerodynamics (as far as I know, Ford hasn't put much Aero effort into its HD trucks) would more than likely keep the turbo's spooled or closer to being spooled. For a gas motor, this would actually decrease efficiency. The more time an engine can spend off of turbo (acting like a naturally aspirated motor of its displacement) and provide enough thrust to maintain speed or perform modest acceleration, the more fuel saving the motor is. The idea of the high horsepower and torque rating on the ecoboost is that the power and torque would only be needed for heavy loads and acceleration. From many rags like pickuptrucks.com, there isn't any gain in towing fuel economy in ecoboost vs. 5.0 v8 (some reported a slight detriment in mpg). However unloaded the ecoboost shines as it doesn't need to dip into boost for daily driving unless the driver feels like having some "Fun". Putting the motor in a superduty would be like towing a small weight at all times and diminishing the ability of the 3.5 to save fuel over the 6.2.
Basically turbocharging is just another method of displacement-on-demand. For every 14.7 psi of boost, you've added another engine of the same size. Only thing bad about turbocharging is that you do need to run a little richer than 14:1 afr. Even with direct injection (though with old-school port injection you needed to maintain 11:1 afr, I beleive the dip is only down to 12.5 or 13:1 for gasoline direct injection).
E'Aho L'ua
Turtle_n_Peeps
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Wes_Tausend
The reason Ford doesn't offer the 3.5 EB in a 250 is that the heavier rear axle in these trucks irrevocably drags the mileage down. A 3/4 ton with a 1/2 ton axle would get similar fuel economy as the 1/2 ton itself, or visa-versa, the 3/4 ton axle in a 1/2 ton would suffer the same poor fuel economy as the average stock 3/4 ton.
So the expensive variable displacement, aka turbo, in the EB would seldom run at the economy of only 3.5L normally aspirated, and not achieve the EPA target that the 1/2 ton does. It would always have to run at slight boost.
In other words, 20 hp might move a easy rolling 1/2 ton at 65 mph, but the 3/4 ton would require 30 hp to roll the same conditions. It is just as well to use a cheaper larger displacement engine at low throttle than a small engine always at slight boost.
So for that "efficiency" reason I would like to run a 3.5L EB in my Excursion, instead of the V-10, just to see.
Wes
bmanning
johndeerefarmer wrote:
3.5 eco is not maxed out power wise. Lots and lots of guys are running tunes with 80 or more extra hp and 120 ft lbs of torque.
Ford overbuilt the 3.5 block so it can handle this extra power. I have heard of no tranny's failing but one guy lost a rear end probably becaus he towed 15k
That's like saying my blown SBC is not maxed out at 600 HP. I could always go 40% over on the blower and make 1,000 HP. :R
This is an easy formula:
When power goes up, duty cycle goes down.
When power goes down, duty cycle goes up.
How high of a duty cycle do you want? How much power you want?
And how many Ecoboost F-150's have you seen pulling a 53' reefer trailer long haul?
LOL Well that is true but can't that be said of ANY of the little light duties (yes, that includes 1-ton diesels) sitting on dealer lots?
The private-use benchmark these days among pickups seems to be the 2013/2014 Ram 3500s with their 37000lb GCWR, but if I see one coming down the highway with a 53' van behind it I'm changing lanes and giving it a whole lot of breathing room.
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
Fordlover
2016 Skyline Layton Javelin 285BH
2018 F-250 Lariat Crew 6.2 Gas 4x4 FX4 4.30 Gear
2007 Infiniti G35 Sport 6 speed daily driver
Retired 2002 Ford Explorer 4.6 V8 4x4
Sold 2007 Crossroads Sunset Trail ST19CK
otrfun
Gotta revise and repost this.
larry_barnhart
WHO CARE'S????
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Me Again wrote:
"Do you have any idea why Ford does not put their big beast 400 freeking HP fire breathing 6.7 in a class 8 truck? I do. It's called duty cycle............or lack there of."
And what diesel goes in the F650? That's right a midium duty Cummins 6.7. Both the PS and Duramax are consided light duty engines.
Chris
And Fords V10 engine that's used in these F650 trucks are considered "medium duty"? I believe your analysis is a failure and your motives are obvious! :W
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Hannibal
Class 6 is a Medium Duty truck. Ford offers a 200hp Cummins or a 362hp gas engine in their F650. Have no doubt which one will tow faster up the hill. Cummins offers the 6.7L for small motorhomes. The 8.3L, ISL9 and ISX15 are offered for the big guys. On our next cruise, I'll ask if the 6.7L is pushing our ship through the Caribbean. The Cummins B series does make a cool novelty engine for the family car though.:B
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
