โMar-18-2018 04:42 PM
โMar-20-2018 05:16 AM
toedtoes wrote:
I'm going to argue that if a portable heater is causing your breakers to trip, then you've got a wiring problem.
Now if you routinely run multiple high usage items at the same time on one circuit then that's different. But just a portable heater during the night should not trip your breaker.
โMar-19-2018 09:56 PM
โMar-19-2018 08:05 PM
โMar-19-2018 06:39 PM
BarneyS wrote:
We did not have a problem with the electric plugs in our trailer getting warm but with all the cool weather we had down in Florida several years ago we needed a way to run our electric heater without going through the trailers electrical system. I put in a waterproof outside receptical and an inside outlet in the side of our slide out. Now we can run the electric heater or other higher usage items like toaster or frying pan without worrying about tripping the trailers breaker when we turn on the water heater or air conditioner at the same time.
Works great!
The device that I used was this one from West Marine.
Barney
Quite a simple mod.
โMar-19-2018 04:51 PM
โMar-19-2018 04:19 PM
โMar-19-2018 02:07 PM
pianotuna wrote:
Fast but not so safe.
https://youtu.be/3wcdblWPGKE
โMar-19-2018 01:56 PM
โMar-19-2018 01:55 PM
dfm wrote:
We have been using a Vornado electric heater for the past several years. It circulates the heat very well with a large, quiet fan, and has a thermostat and adjustable heat output. We have been very pleased with its' performance during temps down to as low as the high 30's in our 30ft trailer. You can barely hear the fan running when it is on high position.
X2
โMar-19-2018 01:43 PM
Lynnmor wrote:
I got rid of my insulation displacement connectors and sleep very well knowing that the wiring is held in place by being wrapped around a screw and tightened. Jamming a copper wire into a slot makes for a connection dependent on a sheared edge holding it with just the spring tension of the part. I took my own good advice and took out the trash.
โMar-19-2018 12:20 PM
โMar-19-2018 11:57 AM
pianotuna wrote:
Hi ScottG,
That is truly bad advice. Have you actually inspected a stab connector after it has been used for 1 month of constant use? I have, and it isn't pretty.
The stab connectors are garbage. Get rid of them if it is possible.ScottG wrote:
Never had any problems with the so-called "Stab connectors" in any RV and running a space heater. Been doing so for a couple of decades and never had one get warm. They are UL and CSA rated for the full load just like normal residential outlets and there are 10's of millions of RV's using them without issue.
So I would not worry about changing the outlets, just monitor for heat like you should with any space heater.
โMar-19-2018 09:27 AM
โMar-19-2018 09:15 AM
โMar-19-2018 09:04 AM
