erdvm1 wrote:
Are there any specific issue I should be aware of before buying
Such as check tube diameter
What about the motor on top style (Atwood) do they interfere with letting the bunk down
Kodiak 172E 2014
Anything else to consider so I buy the right one. Thanks
there are two different size holes. so you need to measure yours, to make sure.
yes, the motor may be too high on some models. you need to measure the height from the mounting plate to the top of the motor and compare that to what the distance from the bottom of the open bunk door is to the A-frame. also, if you have a truck tailgate, it may interfere also.
i had to turn my UF3500's motor 180 to clear the tailgate. but it doesn't affect the bunk door.
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
