Jun-20-2022 05:34 PM
Jun-20-2022 08:03 PM
maria_bettina wrote:
Yes, I am bummed.
Jun-20-2022 08:00 PM
maria_bettina wrote:Nope a 250W DC heater: 250W/12V = 20A+, ie It will draw 20A+ DC amps.
But if that same 250 Watt heater was DC, that's a whole different story. Electricity is like magic. Totally boggles my mind! Haha
Jun-20-2022 07:47 PM
stevenal wrote:
Once the fuse blowing issue is solved, I expect you'll be dealing with battery capacity. Heating appliances will draw your battery down very quickly.
Jun-20-2022 07:40 PM
time2roll wrote:
Inverter should draw power direct from the battery using #8 wire minimum. 250w is close to 25 amps at 12 volts.
Jun-20-2022 07:36 PM
shastagary wrote:
this is what it says on the amazon page of that inverter that i also own. it can easily draw more than 10 amps with the heater loadIf the rated input of any connected AC devices exceed 150W, please use battery clamps to directly connect to your vehicle's battery as most vehicles' 12V cigarette lighter ports are rated for 150W. Do not use to power high power electric devices such as hair dryers, electric heaters, which might blow a fuse.
Jun-20-2022 07:33 PM
2112 wrote:
I'm curious toi know what heater you are using. The link you provided directs me to the inverter.
Jun-20-2022 07:26 PM
Jun-20-2022 07:24 PM
Jun-20-2022 07:17 PM
Jun-20-2022 07:15 PM
Jun-20-2022 07:11 PM
Jun-20-2022 06:12 PM
Hi! I bought a 250 Watt Electric Heater to stave off the chill at night (the tag says it uses 2.1A). We have solar panels to charge our 200A battery (I don't think that matters, but just in case).
Before the trip, I plugged the 250 Watt Heater into the 300 Watt inverter, and the inverter is plugged into the cigarette lighter in the camper. (The wire that runs from the cigarette lighter to the battery sized for 10A.) It worked fine. But now that my son and husband are on their trip, when they plug in the heater, the 10A fuse blows that is at the cigarette lighter. Twice.
They are able to play a DVD and TV by plugging it into the inverter. So everything works for the DVD and TV.
Nothing else is being charged or used on that inverter, nor at the cigarette lighter.
Note: There is an electric fridge/cooler, and it's being powered by the same auxiliary battery, but it's not on the same fuse (if that makes sense; I know I am not using the correct terminology).
My hubby just got to a campsite that has a power supply, and the heater works fine. So at least he is able to use it now without blowing fuses.
Any suggestions as to where we can start looking for the issue(s)?
TIA.
Jun-20-2022 05:58 PM
jimh406 wrote:
My first guess is the antenna amplifier is on. Many power outlets get their power from the same circuit the antenna amplifier is on. Turn the amplifier is off. Many have an LED to show if they are on or not.
Otherwise, check to see what else is off when the fuse blows just to make sure something else like a fridge etc isn't drawing a bit of power from the same circuit.
Also, it may make a difference at what the setting is on the heater for temperature. The difference in the surge could be different if you turn it all of the way down, turn it on, and then gradually turn the thermostat up.
Jun-20-2022 05:45 PM
