Jan-23-2014 07:50 AM
Jan-27-2014 09:49 PM
Jan-27-2014 09:35 PM
Jan-27-2014 04:31 PM
ewarnerusa wrote:
This pair of 12V batteries lasted for a week of boondocking and you suspect they are bad? Seems quite good to me.
Jan-27-2014 04:35 AM
whizbang wrote:
Test instruments are a beautiful thing.
You need to get an ammeter in line to measure your discharge current.
Personally, I have bought new batteries that were no good.
You either have excessive current draws or bad batteries.
Perhaps you can get the batteries tested.
Jan-26-2014 09:10 AM
Jan-24-2014 07:09 AM
Jan-24-2014 07:06 AM
smkettner wrote:
Mount the 120w to the side so there is room for a second 120w if needed.
Make sure your roof items cast no shadows on the panel. Even a small shadow on a single cell can cut production to near zero.
Jan-24-2014 07:05 AM
Simplygib wrote:
Campermama - just trying to hazard a guess at your electrical usage based on your description and what my appliances draw, which may or may not match yours.
"A few showers" - my water pump draws about 7 amps. Assuming a shower takes 10 minutes that would be about 1.16 amps per shower. So lets say 3.5 for three of them. Note - I doubt you meant three showers in one day. If you're talking about one shower a day, this number would be 1.16. But for fun lets just say 3.5.
Lights - I'll assume you have incandescent bulbs and you burn two of them for 15 minutes a night. They usually use about 1.5 to 2 amps per bulb, so lets say 1 amp for lighting (since you're only using light for 15 minutes).
Heater - my heater fan draws 2.5 amps. Lets say three hours a day of heater use, so 7.5 amps there.
Fridge - I don't know what kind of fridge you have but I assume you're running it on propane. Still, there is a circuit board inside of it that probably draws about half an amp, 24 hours a day. This is going to be your biggest draw, unless there are other draws you forgot to mention. 12 amps.
These are all guesses, of course.
So we have 12 + 7.5 + 1 + 3.5 = 24 amps.
If that's correct, you have to put maybe 26 or so amps back into your battery bank on a daily basis (need to add more than you use due to inefficiencies in the system).
That amount of usage is about the same for me. I have 200 watts of solar on the roof and a 220 amp hour battery bank (two 6v batts). In your area (I'm usually out there for a month or so each winter) I can be recharged by noon or so each day. My panels tilt, which helps in winter.
With 120 watts I think you would be fine most days, probably getting totally recharged by mid afternoon or so.
Of course this is all based on guess work (as to your actual power usage) and the assumption that your solar system is set up correctly and your panel will tilt. If mounted flat it will take longer this time of year.
Hope this helps.....
Jan-23-2014 08:15 PM
Jan-23-2014 07:54 PM
Jan-23-2014 07:34 PM
Jan-23-2014 06:25 PM
campermama wrote:whizbang wrote:
+1 what Redsky said.
I don't think your batteries are in good working condition.
??? batteries are brand new! Bought them a week ago. It is the small capacity solar panel that is the problem.
Like I said already, I use the lights a total of like 10 minutes a day! Don't need to switch to LED's for that.
Jan-23-2014 05:27 PM
Oldtymeflyr wrote:
We have an 85 watt panel and it has worked okay with a two 6 volt 235 amp deep cells. We are good for two days in the winter without starting up the truck. Our camper has LED's because we use the lights in the winter quite a lot.
Next on our list is a 140 watt panel, our controller is good to about 25 watts. My recommendation is to bite the bullet and go with a bigger panel and a bigger controller.
The thing I really like about solar is that its always trying to work, if there is enough light its working. A generator is noisy, dirty, takes a lot of valuable time and work. Solar is the best.
Good Luck!
Jan-23-2014 04:53 PM
