โDec-23-2014 05:58 AM
โDec-23-2014 06:42 PM
โDec-23-2014 05:11 PM
โDec-23-2014 02:24 PM
โDec-23-2014 02:16 PM
goducks10 wrote:GrandpaKip wrote:
They make all kinds of racket. Another reason I got the Andersen hitch, besides the grease.
x2.
โDec-23-2014 01:35 PM
cmoecmoe wrote:
From the manual... "Lubricating the socket joint may help reduce this noise, and is part of the required regular maintenance routine. Lubricating the L-bracket joint is optional. A better solution is a set of official Equal-i-zer brand Sway Bracket Jacketsโข. They quiet the ride without the mess of using a lubricant.
The noise is also addressed on the FAQ section of their web site. http://www.equalizerhitch.com/Equal-i-zer%20Support/faqs.php
Craig
NOTE: Utilizing lubrication on the Equal-i-zer L-Bracket, in the form of the Sway Bracket Jacket or any grease type lubricant, may lessen or decrease your sway control by a small degree.
โDec-23-2014 12:00 PM
downtheroad wrote:
Equal-i-zer Brand hitches...pop, snap, squeal and screech.
Normal.
โDec-23-2014 10:37 AM
โDec-23-2014 10:33 AM
โDec-23-2014 08:04 AM
downtheroad wrote:
Someone above advised you to grease all the contact points....I would not do this as it will keep the sway components from doing their job.
You can and should grease the hitch ball and the trunnion bar ends that attach to the hitch head....but not grease the trunnion bar ends that contact the saddles.
โDec-23-2014 07:45 AM
cmoecmoe wrote:
You can use lithium grease to lube up all the contact points and it will help with the noise. They all groan/pop and make noise as there is a lot of pressure there to "level" out the trailer/tow vehicle.
โDec-23-2014 07:44 AM
โDec-23-2014 07:15 AM
Normal.
I appreciate the audible notification that it is doing its job.
โDec-23-2014 07:07 AM
Normal.
โDec-23-2014 06:48 AM
