Feb-05-2016 01:15 PM
Feb-07-2016 11:30 PM
wvabeer wrote:
I told you the weight police would be all over you. If you had asked what truck to get to full time camp I'd say a 1 ton but if you camp 3 or 4 times a year, get what you want. The new f150's are very capable. Whether you get a 1 ton or 1/2 ton you're going to have to get air bags or some sort of propping up. Granted I am way overloaded but it hauls the load comfortably and confidently. I just don't go heavier than the max payload f150 as the axles and bearings are the same.
These guys are right about weight, the sticker is usually wrong. my sticker says 1680lb on a scale its 2280. So weight it.
Feb-07-2016 02:55 PM
jefe 4x4 wrote:
There's always the option of casting a wide net and buying a used truck and camper already assembled into a unit. That means truck with camper already on. This will save a lot of grief and upgrade time as the former owner probably had to add beefier suspension parts to haul the load. Several on this forum have gone this route. I've seen these around, and if you can find the one that fits your style and budget you could suffer many happy years of truck camping. A wide net is basically 1K miles; a half pie, mostly to the south, SE, and SW in your case.
As with many neophytes, I see the ultimate change in paradigm from, "my 1/2 ton with that BIG Ford 9" rear end can haul anything" school to, "I gotta have more truck". (aka: bigger brakes; heftier frame; heftier axles, bearings and housings; appropriate suspension parts; sturdier transmission/transfer case/drivetrain parts.) It all keeps you away from the edge of overloading.
jefe
Feb-07-2016 01:57 PM
Feb-07-2016 11:50 AM
Feb-07-2016 08:50 AM
Feb-07-2016 07:09 AM
Feb-06-2016 07:08 PM
Feb-06-2016 06:45 PM
Grit dog wrote:Steve_in_29 wrote:
" Also keep in mind the load capacity ratings on 1/2 ton trucks are the MAX they can carry for a SHORT distance. Such as bringing home a load from Home Depot. While the ratings on 3/4 ton and up are the weights they are expected to be able to lug around day-in-and-day-out for years."
Haha, wherever did you hear that??? That's gotta be the best weight cop story I've ever heard. Fictional story......
Anyway, yes the half tons are going to be maxed out and need extra springs or bags or something but full size 1/2 ton trucks are not near as anemic as some make them out to be.
Would a 2500 min haul a camper better? Yes, but if you're on a budget and looking for good mileage the rest of the year, a HD gasser is the wrong truck for that and a diesel is much more expensive.
I guess just heed the good advice here by making sure you think out the choice before plopping down the scratch on a new rig.
Feb-06-2016 05:43 PM
Feb-06-2016 05:13 PM
Feb-06-2016 04:42 PM
Feb-06-2016 03:57 PM
steeds wrote:hedgehopper wrote:steeds wrote:Figure 500 to 1000 lbs for propane, water, passengers, and gear.
so really even a camper that is around 1200 pounds, and loaded being 1300-1400.
assuming a camper says 1050 dry weight and it is shipped then the side says 1120lbs. battery say 60lbs tops, propane 20lbs. water at 9 gallons...assuming 25-40 pounds. and clothing/cooking etc say is 80-120lbs. myself 165.
but even then, i wouldn't travel with water in there till a city close to camp.
Feb-06-2016 03:54 PM
Feb-06-2016 03:32 PM
Feb-06-2016 03:05 PM
