โJul-09-2014 05:52 AM
โJul-15-2014 05:04 PM
Happy Camper83 wrote:
Thank you for all the help.I was hoping I could add something to it to get my GVWR up.
โJul-15-2014 03:26 PM
spoon059 wrote:
I think you are misunderstanding the numbers...?
What is the available payload for your truck and what is the weight pin weight of your 5er?
To answer your question though, there is nothing you can do to change your GVWR. Air bags will upgrade the suspension portion, but you still have to worry about braking, axle weights, tire weights, etc etc.
โJul-10-2014 05:24 AM
โJul-09-2014 01:03 PM
โJul-09-2014 12:09 PM
โJul-09-2014 11:21 AM
mdamerell wrote:
My 2004 F350 GVWR is 11,500# and weights 8,000# (with us in it) so I have a 3,500# payload. If you look at the axle and tire ratings you could probably carry more. Legal is based on tires and axle ratings along with what it's actually plated for.
A GVWR of 11,200# I suspect you have the 4x4 version.
18,100# x 20% = 3620# pin. It will be a little lower is the trailer is not loaded to gross.
โJul-09-2014 10:33 AM
โJul-09-2014 08:22 AM
โJul-09-2014 08:08 AM
โJul-09-2014 07:41 AM
About 7000 # I'm guessing
โJul-09-2014 07:17 AM
โJul-09-2014 06:39 AM
โJul-09-2014 06:28 AM
