Firestone Airbags 2013 Silverado
BubbaK
Is there anyone that is using these airbags that can give me some insight on how they like or dislike them. Will be using them with a WD hitch installed. Just wanted to get some feedback before buying the kit.
26 REPLIES 26
bigcitypopo
I have the ride-rites on my f150.. love them... its a two man job.. 3 hrs... I ordered from Auto Anything.... 330 to my door
air valves to the Lic plate holes.... no drama ,work great, i tow a 6100lb TT... loaded its 7300.... no more bounce while towing...
do it again in a heartbeat
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
nremtp143
popeyemth wrote:
going the same way with no bells and whistles on our 2007 to level the truck camper.
anyone recommend the cheapest place to get Firestone bags? would like to get in the next few days.
we are itching to go after rebuilding the roof ๐Ÿ™‚
There are many places out there that sell them, and occasionally have sale prices. Here are a few examples: Jegs.com, truckaddons.com, sdtrucksprings.com, etrailer.com, summitracing.com, and you can even try Ebay after going hereFirestone Info site to find out which set is for you. I strongly recommend a "No Drill" kit.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
Paul_Clancy
Bags on my last 3 trucks. Includes my current 2009 d/a. Great ride and adjustability. Won't tow without them.
lamopar
I have had the Firestone bags on my truck for three years. I use it to help with the load of the trailer, I have hauled 2.5 tons of stone in the back with them, and lower the pressure and they ride just fine. I just bought the pump kit for them and it is sitting on the kitchen island now. I wanted it for a time like now when I tow to a camp site then want to lower the pressure to drive around but need it back up when it is time to go.
popeyemth
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
BubbaK
cdlaine wrote:
Bubba..
Recently had some added to my Silverado... dialed in
about 40 PSI for towing (pin wt. at 2600 #'s). Performs as
expected...levels the combo, probably brings the headlights
out of sky search mode. Notably "firmer" ride, truck sits
higher (noticeable from the cab),... a little harder for the
vertically challenged Princess to get in an out of the truck...
but not significantly...just warn your S.O. as the first step
out may not be where she thinks it should be... I had not
thought thru that they would be removing the bump stops...
but understandably necessary...so, so get them / save them upon
install... as you may change your mind down the road. Have
not found the perfect "empty" PSI.... somewhere in the neighbor
hood of 10 - 14 PSI.... needs more trial and error.
Sure can dial in "level" .... not sure as to "comfort" but that
is the co-pilots realm...she'll let me know...
did not go "fancy" dual controls, monitors...etc. ,...refill
nipples located at the rear license plate.
Charles
I am going the same way. No bells or whistles just the bags. Do you have any pictures?
JustLabs
301TBS wrote:
Have you considered Timbrin's? They are another option to look at, and no worries about air leaks.
I have Timbrens on my 2011. No change in ride and they work as well as the air bags I had on my last truck.
2011 Chevrolet 2500HD LTZ 4x4 CCLB Duramax/Allison
2007 Keystone Cougar 289BHS Fifth Wheel.
cdlaine
Bubba..
Charles
2003 2500HD, 8.1L,CC,4.10,2WD,Allison
Standard bed
Ride-rite air bags
Prodigy
Husky 16K sliding
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
I'll want the Frim Fram sauce with the Ausen Fey with
Chafafa on the side.... Nat
BubbaK
I have looked at the Timbrins and thought I mite get a little more adjustment out of the bags if needed.
301TBS
2019 Springdale 240BH
2009 F150 Scab 4x4, 4.6, 3v. 6spd. 3.73/9.75
Reese dual cam
BubbaK
donn0128 wrote:
Had them on an earlier version. Worked just fine and easy to install. But I have to ask what you intend them to do for you? If it is to cure/help an overloaded situation all I can say is it is going to be a band aid and not a cure all. If it is to he stabilize the load, then have you also considered new shocks?
Just looking for a better ride when towing the TT. Make the truck a little more stable on the HWY. I have yet to tow my new trailer (ordered from the dealer) but am going to tow my friends TT in a few weeks that will weigh just a little more than the one I am getting (8000 max loaded will end up being 7600 real numbers). Also, I am one that if the bags will help in any way to make the ride better, I'm game. I like to find an excuse to add things like this to the new truck but want to make some kind of gain by doing it.
donn0128
