Mar-21-2020 04:45 PM
Mar-25-2020 09:44 AM
bucky wrote:
Yes, that would be one of the earliest Allisons behind a DM. Allison trannys are one of the best if not the best in the industry. They are used in different configurations all over the world. The issue with the longevity in the early DMs was that GM speced the tranny to the stock power as the DM power numbers increased over the years. Tuning and hot rodding a 02 DM without the needed upgrades to the tranny will not end well. That's all I'm saying and that is why I suggested a straight drive (manual) trans behind that behemoth 502 in that older Ford truck.
Mar-25-2020 05:22 AM
Mar-24-2020 09:45 AM
bucky wrote:Turtle n Peeps wrote:bucky wrote:
A stock 1000 Allison won't last with those hp and torques numbers. Put a straight drive behind with a good clutch and have fun. YeeeeeHaaaaaaaaaaaw.
Bowtie in the back window optional.
Why is that when a stock DM HP numbers are higher than that gas engine and torque numbers are WAY higher?
Saw a lot of tuned Duramax trucks during my working years with blown Allison trannys that warranty would not cover. That 502 engine in a 90 Ford truck will not have the software to minimize the issue. I'm only referencing the light duty Allisons, not the models specifically designed and installed in behemoth MHs and newer model big number 2500 and 3500 pick ups. His application would require a tranny rework to last is all I'm saying.
Mar-24-2020 08:39 AM
Mar-24-2020 03:51 AM
Mar-23-2020 06:54 PM
Mar-23-2020 06:34 PM
Cummins12V98 wrote:
FISH too funny on the vid, this guy has a shop that works on there trucks. He is trying to get business!
The 6 speed is very rare for a second gen and they are considered the trans to have. FACT is the 5 speed that is common has the 5th gear nut issue but I bet everyone of them out there has had theirs repaired.
Sure some of these things can go wrong on any truck that's 18-28 years old!
Bottom line they hold their value better than the others of the same era for good reason.
Mar-23-2020 01:50 PM
Mar-23-2020 01:44 PM
Mar-23-2020 01:41 PM
Grit dog wrote:FishOnOne wrote:Cummins12V98 wrote:
"If I were considering a radical swap like that I'd go for a built 12V B series Cummins, but that's just me."
Lots of people do that conversion, "FUMMINS"
I've yet to see one in the wild. As a matter of fact it's been many...many...years since I've seen a 12v.
Maybe Texans aren’t as resourceful...lol.
Plenty of guys re-purposing otherwise worthless Fords with 12Vs around here.
Mar-23-2020 12:59 PM
Mar-23-2020 12:27 PM
BenK wrote:
Similar situation with my Suburban
Looked at that GM 502 crate engine and decided to rebuild the 7.4L
Passing CA smog a must and no one have an acceptable answer on the 502
So my 7.4L is looking to have a 280 cam, roller rockers, 9.x compression, worked head, marched injectors, etc to be a bit under 500 ft/lbs around 2-2.5 KRPMs, etc
Built 4L80E rated 1KHP
Gearvenders with the splitter option, 0.5 OD, which will turn the 4 speed into an 8 speed
5.38 diffs, but having a tough time finding it for the front
That will give a lower 1st and higher OD
Don't know if the Xfrcase will need beefing up
1996 K3500 Sub and fits/suits me
Either LT255/85R16 or LT285/75R16 on current 10" wide alloys. Not going to lift...maybe a torsion bar crank
Still deciding...
Mar-23-2020 11:25 AM
time2roll wrote:
https://www.chevrolet.com/performance/crate-engines/big-block-ram-jet-502
Mar-23-2020 11:23 AM
Still deciding...
