Nov-01-2016 09:13 AM
Nov-10-2016 05:27 AM
Area13 wrote:
Good luck Billyray. Just filled mine up again the other day (same exact camper) and did just fine. Must be kinked or blocked. Hope you get it figured out soon and feel free to PM me again anytime if you want me to reference things or such.
Nov-03-2016 10:16 AM
Nov-03-2016 08:33 AM
billyray50 wrote:
Well I would agree other than the fact if you look at the my pic showing fill line the water tank is all the way in the front of camper so no way the 4 foot hose enters the fresh water tank.
Nov-02-2016 12:08 PM
mkirsch wrote:
You're overthinking this.
You already shoved a hose down the fill tube and determined that there was an obstruction. Once past the obstruction you could fill just fine.
That means the vent tube is fine.
The obstruction is in the fill tube.
Nov-02-2016 11:20 AM
Nov-02-2016 07:20 AM
Nov-02-2016 06:49 AM
Nov-01-2016 07:19 PM
Nov-01-2016 07:17 PM
AnEv942 wrote:
Why not leave new hose in fill line?
As I needed to use a piece of hose with cut off end anyway-after a few times pulling it in and out I realized it could just live there. Filed off about 1/8" from female hose end so cap would screw back on.
Ours just chokes, no kinks-fair slope but unless filling really slow just easier for water to come back out. No issues with the additional hose, also vents around it. I only pull out enough to attach hose- inch or 2
Only caution is with the added hose, too easy to turn water volume up since it will take it, but also easy to pressurize the tank. If I can hear the air I turn down.
Nov-01-2016 04:22 PM
Nov-01-2016 04:06 PM
Nov-01-2016 04:02 PM
Nov-01-2016 04:00 PM
Nov-01-2016 11:31 AM
billyray50 wrote:
Yes Bedlam i think so too. In first pic the freshwater line lays over that copper pipe and from my view since i cannot get in that far in basement storage hose has a narrower shape to it.
