Fridge issue
me_camper
The other day I got back to the rv, went to get some ice for a drink. Got the ice out of the freezer only it was water. Fridge stopped working. Was on auto but never switched to gas. Switched to gas manually and fridge works fine. Breakers and fuses inside rv ok, power at fridge outlet ok. Any ideas, Thanks.
2005 GMC 2500HD 4X4 Crew Cab
6.0L,4:10
2011 Coachman Freedom Express 296REDS
8 REPLIES 8
profdant139
The indicator lights on most RV fridges are so counter-intuitive -- if it is running on gas, and everything is working properly, no lights are lit. If there is a problem, the "check" light is lit. That looks a lot like the "auto" light.
It is easy to mistake the check light for the auto light. When looking at the fridge when it is on gas, you have to consciously remember that "no light on" is the desired outcome. Very poor human engineering.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
opnspaces
Navigator II
Navigator II
I never trust the Auto switch setting on mine as it sometimes malfunctions. So anytime it switches from electric to gas I just look at the indicator lights to make sure they are on and not blinking. If they are blinking I flip the switch off and back on and it has always worked from that point. Been that way for 15 years so I'm not worrying about it.
Old-Biscuit
IF it had attempted to swap to gas and failed it would have "CHECK" error
It was STILL in 'Auto' and OP Manually swapped it to gas
OP stated
120V AC power was still available, breakers/fuses all good
AC was available, fridge in auto but NO Cooling action going on
BAD element or bad circuit board
wnjj
profdant139 wrote:
Joel, he mentioned that when he switched to gas, it lit. So maybe there was gas flowing to the fridge and there might be something wrong with the circuit controlling the switch?? I sure hope not -- it is expensive to replace the electronics.
But I agree with Joel that before lighting the fridge, I always run the stove for a minute to get the air out of the line. If I don't do that, and if I then try to run the fridge on gas, it takes quite a few clicks by the automatic ignition system to get the fridge up and running.
If I purge the line, though, it fires up on the second click.
Yes, but switching to gas manually gave it one more chance. It may have needed purged and the automatic switchover gave up after trying to light.
Itโ€™s easy to test. Provide power when itโ€™s running on gas on auto then pull the power and see if it lights up again.
profdant139
About our trailer
joelc
Before your fridge, water heater or any appliance you must be sure you have gas going to the appliance. The best way to do this is light you stove top and after you get a flame then try your appliance. This is required if you unit is sitting awhile and there is no gas yet to the appliance. In other words, you purge the gas line.
joelc
joelc
