Nov-20-2021 07:55 AM
Jan-22-2022 05:39 AM
Jan-09-2022 06:07 AM
MFL wrote:goducks10 wrote:GrandpaKip wrote:
Umm…didja notice the question mark? Not a statement, maybe a rhetorical question.
Yes it was meant to be rhetorical.
Good catch Kip!
So many just jump in, with no reading comprehension, or skip over posts, and then miss the point of discussion. As threads progress, often times the entire subject may change. All good though, as forums are a source of information and opinions.
Jerry
Jan-08-2022 08:53 AM
Jan-08-2022 07:45 AM
Jan-08-2022 06:57 AM
Jan-07-2022 02:18 PM
Jan-07-2022 12:38 PM
nickthehunter wrote:goducks10 wrote:What makes you think so? That statement has no basis in fact. In one scenario you have a trailer weighing 60% more than the truck pushing around the truck; In the other scenario you have a trailer that weighs 100% more than the truck pushing around the truck. I'm highly skeptical your claim, and how would you measure "safer" to begin with. Its a pure nonsense statement.
An 8,000lb 3500 SRW truck towing 16,000 lbs is safer than a 4,000lb truck towing 6400 lbs?
Jan-07-2022 08:54 AM
Jan-05-2022 06:36 PM
Urriellu wrote:
Thank you all very, very much for all the replies.
I just finished a second trip and I made a few changes as suggested:
- I went from 65-75 mph avg to 55mph.
- When going uphill I slowed down to 45 mph.
- I started using premium gas instead of regular.
- I speed up after stopping veeeeeeery slowly.
My consumption has gone up from 7.5-8.5 mpg to around 12 mpg. Way better!
Just using premium instead of regular also helped a lot, when not towing I went from ~18 mpg (using regular) to 21-22 mpg (using premium).
Thanks again!
Jan-05-2022 02:33 PM
goducks10 wrote:Point taken 🙂 , although I wouldn't want to be anywhere near either one in an emergency maneuver!
Jan-05-2022 02:23 PM
Thanks again!
Jan-05-2022 01:17 PM
Jan-05-2022 12:42 PM
Jan-05-2022 11:02 AM
Jan-05-2022 10:26 AM
Gdetrailer wrote:Agreed that with the correct trailer brakes, the tow vehice can stop the trailer, even in an emergency stop situation. I'm more interested in an emergency "maneuver", such as swerving to avoid another vehicle or something. In that scenario, the trailer brakes are of little value, and the mismatch in weight between the trailer and the truck becomes a major factor in control (or lack thereof)..4x4van wrote:
I have to laugh at the tow capacity wars that the manufacturers are currently waging with small/midsize trucks. Towing a 6400lb trailer with a small 4000lb truck at 75mph? While it may be able to TOW it, and it may be able to STOP it (with trailer brakes), in an emergency maneuver, the trailer will drive the truck. Hope I'm nowhere near the OP when that happens.
Trailer brakes generally are required items once you go above 2,001 lbs in some states and 3,001 lbs in most all other States. So in reality, yes, a "4,000 lb" truck CAN safely not only tow but STOP.
The trucks brakes handles the weight on the truck up to the rated GVWR and the trailers brakes handles the trailers weight up to the rated GVWR.
So in reality, it CAN be safely done, might not be pretty or fun but still very possible to safely stop during emergency maneuvers.
A lot of folks out there towing even greater of a mismatch, while that doesn't make me feel safe it is the reality we must deal with. Eventually with a big and heavy enough trailer even a F450-F550 truck will be much lighter than the trailer..
My personal feeling is I would much rather have a bit beefier tow vehicle to start with which provides a firmer platform (IE stiffer springs, firmer shocks and some added weight to match closer to the trailer's weight). But obviously not many people are willing to step off the 1/2 ton platform because they prefer the softer ride and a perceived lower cost to buy and a couple of MPG better mileage when empty.
