Full hook up?
silverbullet555
We are off soon on a trip and the camping site we are using has full hookups. Power and water will be great.
It'll be 4 of us for 4 nights. 2 adults and 2 kids.
A couple questions around the sewer hook up piece. Do you find it more convenient to hook up to sewer when you get there so there are no issues of full tanks later? Both grey and black? Or do you wait and see if you need to.
If you do what do you do with the 90 deg end that goes into the hook up. We have a dump hose that sits in a "case" on the outside of the camper. But, to hook in to the sewer I envision a 90 degree fitting will be advantageous.
This all reminds me that I need to get a fitting for our grey water tank to make it easier to drain cleanly.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
60 REPLIES 60
TxGearhead
^This X 2.
East of the Mississippi you are not likely to drive down a BLM road and start camping. So, I'll take my COE campground and state parks with hook ups. And about May to October you will need A/C.
This "I never use hook ups" snobbery gets old.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
2_Retired
Some here make it sound like doing a full hook up at a FHU site takes forever! DH hooks up electric, then water, then sewer when we arrive at a campsite in less than 5 minutes, tops! We keep black tank closed until full, and the grey water open until last night, as another explained. Before we dump I fill the Black tank through the toilet completely to create a stronger flow when the tank is opened. DH does black first, then grey to help clear the hose. When he's done, I put toilet chemicals in and put about a gallon of water in the closed grey tank. He then unhooks the hose from the RV and rinses out the sewer hose again. It's not time consuming at all. We almost never travel with our water tank full. Water is very heavy (over 8 pounds a gallon!) and we just don't need the extra weight. We carry 2 gallons of water to use, if necessary, for the toilet or for drinking. If we arrive at a CG and don't like the taste of the water, I just get some bottled water at a store. Been doing this for over 45 years and it has always worked for us. We almost always stay at a traditional CG with at least W/E hookups. We dont boondoggle. DH is a disabled Vet so we can now camp in military campgrounds State Parks are our secondt option. Then private ones. We feel it is right to support campgrounds so they can stay in business, not be turned into housing developments! It's getting harder and harder to find a site - if many more CGs 'go under' there will be no place left. We are fortunate to be able to do this.
Two young retirees restless to GO!
Life is too short to wait too long to do all we want to do!!
Go and enjoy!!
StirCrazy
Moderator
Moderator
if I have full hookups in my camper or my 5th wheel I hook everything up when I get there. if I have been camping for a bit with out hookups when I get there I will dump and flush the blackwater tank and leave the grey water open. then I will flush the black again the morning I leave as it saves having to wait in line at the dump. it only takes about 3 minuits to hook it up so I get it all set up then sit down and relax for the rest of the stay.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
Grit_dog
Navigator
Navigator
specta wrote:
Some of you make hooking up the sewer hose sound like it takes forever or its extremely difficult to do.
If you know you're going to use it why not just hook it up when you're setting everything else and be done with it??
Last time I had full hook ups it for three nights, showered every day and did the dishes. The only thing I hooked up to was the electricity.
I just dump and clean the tanks after I get back home.
Itโ€™s rvnet Kennyโ€ฆ
Some could make a 3 page discussion out of putting on your socks in the morning โ€ฆ
Buzzcut1
Nomad II
Nomad II
silverbullet555 wrote:
I take it that if you are not staying hooked up, something like this is essentially useless.
Sewer hose support.
I have been at campgrounds where I might not hook up for days but when I do the supports are essential to getting the hose to dump without me having to constantly lift it to empty it.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
specta
pianotuna wrote:
sewer flies.
Something I've never experienced.
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
pianotuna
Nomad III
Nomad III
sewer flies.
Regards, Don
specta
Kenny
silverbullet555
Sewer hose support.
Torklift mounts
Torklift superhitch
time2roll
Last thing on my mind when setting up is to connect the sewer. It can wait a few days. OK if 4 people need showers twice a day in the RV I would be connecting when the first hops in.
towpro
I had a case where someone bumped the faucet in the bathroom of the 990. We discovered it when we saw the water running out of the web bath, under the door and onto the floor. Luckily we were in AC season so we could get it to dry. The gray tanks was closed.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
Kayteg1
toedtoes wrote:
I just don't see the point of hooking up the sewer hose if it's not needed. Just seems like extra work and a potential tripping hazard.
I love good showers when I can get them and TC gray water tanks don't last longer than for 2 of them.
Again, with Sewer Solution it is 1 minute hookup and relatively clean job.
JRscooby
towpro wrote:
if on a site with sewer, we hook up and pull the gray tank so it drains all the time, but let black tank collect.
than a day before I leave I will shut the gray valve so I have something to flush the hose after I drain the black before leaving.
One of the mods Dad had me do to his 5th wheel was add a small drain about 3/4 up on his grey tank. Open 1 valve, could drain thru hose bib out to bushes, where allowed. Open another, and tied back into stinky slinky. This way he had 3/4 tank to run out behind the black.
If the grey got full before he planed to leave he would bucket some to black
toedtoes
Kayteg1 wrote:
toedtoes wrote:
Why do all that extra setup and takedown if it's not needed?
Where I like to camp - we need AC 24 hr a day.
When our lovely Honda 3000 can provide the power when we stop at rest areas, all dry campings have night generators restrictions.
Still with my senior pass, I am getting water and power camping in most beautiful places for $7 to 10.
Than when you go to prime areas, like TX shore, or Alaska, you have to pay to stay.
I get hooking up to electricity - why not use it since you are paying for it. But that's a quick plug in and unplug.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
towpro
2022 Ford F150
