โMay-30-2015 09:55 PM
โJun-01-2015 07:11 AM
mobeewan wrote:
Do you have room on the tongue in front of the battery to mount a dual tank rack like this one?
Your regulator bracket can be mounted to the tank rack bracket with machine screws and lock nuts probably with the existing holes lining up.
I mounted one of the dual tank racks to the trailer tongue of a pop up and older TT trailer I have that had single tank regulators. I only used the pop up for 3 to 4 day trips. I could change the regulator hose from one tank to the other if needed when I didn't top off tanks before a trip and I could always connect a separate hose and regulator to the second tank for a grill or table top oven I carried. for longer trips I would use the trailer and swap the hose on the tanks as needed.
โMay-31-2015 11:47 PM
โMay-31-2015 11:06 PM
โMay-31-2015 12:20 PM
โMay-31-2015 12:05 PM
โMay-31-2015 08:48 AM
BarneyS wrote:
Here is a much easier way to post pictures on our forums. Just click here. That will take you to a photo hosting webpage developed by our moderator 1492 just for posting pictures.
All you need do is upload your picture to the website, wait a few seconds for the site to do its job, then copy the resulting URL and paste it into your post. No need to use the sub-routine in the posting area or write any additional text or characters. The picture will be properly sized for use on the forums by the website.
It is so easy, even a caveman can do it! ๐
Barney
โMay-31-2015 08:38 AM
โMay-31-2015 08:06 AM
โMay-31-2015 07:11 AM
โMay-31-2015 07:03 AM
โMay-30-2015 11:31 PM
Golden_HVAC wrote:
Hi,
Normally the regulator is attached directly to the 5 gallon tank, and then will go to a switch over tank selector under low propane pressure, then to the pipe that goes to all the appliances. This avoids expensive high pressure propane lines, that would need to be rated at 400 - 500 PSI.
Can you post a picture? That would be first posted to something like PhotoBucket.com and make sure that it is listed as "Anyone can look at it" - so it is not password protected.
Then copy the URL of that picture (CTRL C) and go to the "Advanced post" section, and click on that. Click on the little postcard looking thing, and it will open a new subroutine. On the top line, click on that then (CTRL V) to paste the URL in that box. Put height and width in (not to exceed 600) 500 high and 600 wide usually works well for me.
A picture will help a lot. You might also be looking at the propane leak detector shut off valve. It will run on 12 VDC, so will have two wires going to it. This keeps the propane on until the leak detector trips, then shuts off the valve and propane flow.
Good luck,
Fred.
โMay-30-2015 11:27 PM
mobeewan wrote:
I assume by "box" you mean right at the bottom of the trailer front wall where the hose normally connects. If so and it is for a single tank sounds like they were being cheap with the installation and used a hose and regulator similar to a BBQ grill or other propane appliance.
โMay-30-2015 11:19 PM
โMay-30-2015 10:56 PM
Porsche or Country Coach!
