โJul-23-2017 04:40 PM
โJul-24-2017 07:13 AM
Terryallan wrote:
Not so much the weight, as it is the wall you have to pull thru the air
โJul-24-2017 07:12 AM
โJul-24-2017 07:04 AM
โJul-24-2017 06:51 AM
โJul-24-2017 05:11 AM
โJul-24-2017 05:00 AM
โJul-24-2017 04:36 AM
โJul-24-2017 03:57 AM
โJul-24-2017 01:00 AM
โJul-23-2017 09:31 PM
โJul-23-2017 09:20 PM
โJul-23-2017 07:35 PM
โJul-23-2017 07:31 PM
RinconVTR wrote:JCK wrote:
My trailer 245RBS Bullet weight around 5800 lbs. and pulled with a 2015 GMC 6.2 eight speed 342 gears. Always got between 11 and 12 mpg pulling in 6 or 7 gear at 60 to 65 mph
You got 11-12mpg pulling TT with the 6.2L motor? You may want to evaluate how you're calculating MPG. That's simply too high.
You might get 10mpg at 60mph, but 65mph+ pulling even an empty enclosed trailer at 65mph+, you wont see 11-12mpg.
Exactly as other have said, expect 8mpg-ish. You might see 10 here and there, but not often. And as low as 6 if you have consistent head wind.
โJul-23-2017 07:06 PM
Redwoodcamper wrote:
Just got 13.6 today towing @62-68mph in 90+ degree heat with the AC blasting. Because diesel. My 20ft trailer without any slide outs weights almost 5k fully loaded. I think k your optimistic with your weight.
