Gas or electric water heater
tex_wardfan
Which mode do all of you use. I can use both in my new trailer but I guess I was just wondering which to use and why. I used the gas heater on my last trip to save on watt usage but the people in the big trailer next to me which also had 30 amp usage says they always use the electric water heater.
2016 Sonic by Venture 190vrb
2007 Chevy Silverado 1500 4x4 4.8L V8
30 REPLIES 30
Oasisbob
Propane when boondocking or we need quick recovery. Other times electric as it is already paid for
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
Old-Biscuit
I use BOTH at same time for fastest recovery rate
Pennies here ....pennies there.....it's RVng
DANG the costs :B
Unless someone has changed t-stats.......electric and propane are set for SAME temp control even when they use separate t-stats
Electric is slowest recovery rate
Propane is almost twice as fast recovery rate than electric
Electric/propane together is almost twice as fast recovery rate as propane
Regardless they control to same OEM water in tank Temp setting
Atwood......140*F (Except XT Models then it's 160*F with 130*F outlet temp)
Suburban ....130*F
It's 'self-contained' designed to run off propane with AC as back-up luxury source when available.
It's your RV so use it and the components like they are yours :B
time2roll
I use electric.
If not plugged in I use propane.
If I am using the air conditioner 24/7 I switch to propane.
valhalla360
Nomad III
Nomad III
Electric is first choice. So unless dry camping or if the electric is marginal, we are on electric.
Of course, if we are struggling with enough electric for the air/con we usually aren't needing a lot of hot water.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BB_TX
Depends.
-If on 50 amp hookup I use electric only.
-If on 30 amp hookup in hot weather and running the A/C I may use propane only if running other high current devices to avoid tripping park power.
-If cold weather and incoming water is cold I run it on both electric and propane at the same time to improve recovery rate so as to not run short of hot water in back to back showers or shower while running the washer/dryer.
tex_wardfan
Ok guys, that makes sense. Electric it will be for full hookups.
Wishbone51
I usually use propane, mostly because my propane switch is in the kitchen, while the electric is behind an outside panel, and I don't feel like going outside to turn it on. If there will be several back-to-back showers, I'll use both.
2017 Jayco Jay Feather 25BH
2004 Nissan Titan
MikeInOregon
Electric when in a campground with electric hookup.
Propane when dry camping.
2015 Ford F150 3.5L EcoBoost
2015 Creekside 20FQ
ProPride Hitch
wildtoad
When I had a heater that had both, always used electric but mine was a low wattage add-on system. It would get the water really hot but took a longer time to get it there. When showering or otherwise need hot water faster, I'd use both. Never ever did we just run gas but we also always had electric available.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Jack_Diane_Free
We only use the water heater on gas when there is a power problem within the park (low voltage) or we have multiple other electrical devices running and using electric would trip the park breaker. We will occasionally run both gas and electric together if we need a faster recovery of hot water for multiple showers.
2oldman
I use electric if I only want sorta-hot water. Gas if I want it hot.
the bear II wrote:
besides have you seen the cost of propane lately....
Can't say it's changed much in a long time.
the_bear_II
Always use electric if electric is available. Doesn't make that much difference in the electric bill if charged extra for electric...and besides have you seen the cost of propane lately....
wanderingbob
There will be times that gas makes sense such as when the air cond. or micro-wave are in use , mostly elec at other times !
downtheroad
Use it or not, you are paying for the electricity at your site when you pay your fee...so why not use it rather than using up your propane?
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Pangaea_Ron
TheSidwells wrote:
We have always have had it set to electric and propane as the backup. I figure its easier to pay for the electric then gas. We save our gas for the stove and heat.
x2
I also like to use the RV Park electrons, rather than my propane.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
