Feb-28-2016 06:32 AM
Oct-07-2016 05:46 PM
Jul-10-2016 05:06 AM
Jul-09-2016 08:46 PM
Sport45 wrote:If the 2 tanks are connected together via a gravity feed tube, then the normal fuel level is the level in the aux tank, far above the top of the truck's main tank.
The law essentially says a gasoline tank cannot withdraw fuel from a connection below the fuel level.49 CFR 393.67 (c) wrote:
5. Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
I take this to mean an in-bed auxiliary tank with top connections can pump or siphon to a vehicle main tank without issue.
Jul-09-2016 08:35 PM
Jul-09-2016 08:15 PM
Jul-09-2016 04:13 PM
SoCalDesertRider wrote:Sport45 wrote:I have no idea if there is a law about gravity feeding to the engine in an on-highway vehicle. I don't know why anyone would be trying to do that on a pickup. The gas tank would have to be on top of the hood...SoCalDesertRider wrote:
The law is you cannot have a gasoline aux tank that gravity feeds into another gas tank (ie: feeding into the truck's main factory gas tank). It's legal to do this with diesel, NOT with gasoline.
Is that the law? I thought you weren't allowed to gravity feed to the engine. But I've been wrong before.
There are lots of stationary use engines that use gravity feed tanks instead of a fuel pump, such as generators, lawn mowers, air compressors, water pumps, etc.
Jul-09-2016 01:31 PM
Jul-09-2016 01:35 AM
Jul-08-2016 07:31 PM
Jul-08-2016 10:14 AM
Jul-08-2016 08:34 AM
Jul-07-2016 09:39 PM
Jul-07-2016 09:20 PM
Jun-07-2016 07:33 PM
