Mar-15-2018 08:18 PM
Mar-21-2018 07:02 AM
Mar-21-2018 06:07 AM
APT wrote:
4.10 will just mean 2200rpm at 65mphh is now 2420rpm. That will allow some situations where 5th gear will hold longer. However, 4th gear is now 300rpm higher. I'm not convinced that will be helpful enough to justify $2000-3000. $600 for a custom Black Bear tune will not likely provide much more increased torque at 2200rpm (less than 10% of gearing), but I have heard it greatly improves normal shift programming.
Mar-21-2018 04:06 AM
ericpatt wrote:
Thanks everyone!
Correct. It has the 3.73 and i do use the tow/haul mode. Just double checking cause 3k seemed high as this was the first "big" thing I've towed outside of boats and snowmobiles.
Took a trip last year to Smokey Mountains. Got really nervous when trans started heating up through the hills(~200). Have made it a practice to have it flushed and new filter before long trips. Live in Wisconsin. Heading to Kentucky this spring break.
Had heard that GM was going to put diesels back in surburbans. Might be happening for 2019?? Don't know if i can stomach $80-90k though.....
Mar-18-2018 11:26 AM
Mar-16-2018 12:11 PM
Mar-16-2018 11:49 AM
Mar-16-2018 11:15 AM
Mar-16-2018 10:36 AM
Mar-16-2018 08:13 AM
goducks10 wrote:
All GM 2500 trucks now come with 4.10 standard. Must be a reason.
Mar-16-2018 07:39 AM
Mar-16-2018 06:43 AM
Mar-16-2018 06:16 AM
Mar-16-2018 06:05 AM
Mar-16-2018 05:45 AM
Mar-16-2018 05:37 AM
