Dec-17-2020 06:22 AM
Dec-17-2020 09:30 AM
4x4ord wrote:
Well you certainly don't need a diesel for what you'll be pulling and if you don't want a diesel... get the 7.3 ... who knows you might have less trouble with it than your last truck.
Dec-17-2020 09:18 AM
ognend wrote:4x4ord wrote:
I think the new Powerstrokes are incredible but because you've had problems with your Ford, I'd go to the big city and buy a Duramax if I was you. What will you pay, $6k more for a diesel over a 7.3 gas? 10 years from now you'll get that $6k back. So, to go diesel, it's only costing you interest on the 6k .... about $200 per year and it will save you a little on fuel.
If I were ever going to go to another diesel, it would be to an older truck, not a newer one. The major engine job with my new Powerstroke was a known Ford issue (TSB 16-0041) - which has to do with the emissions system. If you look at the new diesel engines, they are incredibly complicated - they fill up the bay and to get to a part you many times have to take apart half of the top of the engine. The 7.3L gasser, for example, you can see the ground through the engine, it is uncluttered and easy to get to things.
Dec-17-2020 08:38 AM
ShinerBock wrote:
For what you are towing, you do not need a diesel and having one would be a want. I would recommend trying to find a friend or someone you know with a modern gas HD truck and see if they will let you tow with it. Another option is to see if you can rent one for a day from places like U-haul, Home Depot, and so on. Most of the time they are fairly new and renting one for a day is cheap. This may help in the decision making process and it is better to find out in a rental that you can take back versus a purchased vehicle than you can't.
Dec-17-2020 08:02 AM
Dec-17-2020 07:53 AM
MFL wrote:
You seem to have already convinced yourself, that you'd be happy with a gas engine, so I say go for it!!
Dec-17-2020 07:19 AM
Dec-17-2020 07:16 AM
spoon059 wrote:
Sorry to hear about your Ford, I would agree that sounds like a lemon truck rather than known or widespread issues. Word of caution, research the heck out of either truck before you drop the money. My friend bought a 6.4 Hemi with the old 6 speed and only the 3.73 gears. He was not happy with it towing because it had a odd gear spacing and would drop from 4th straight into 2nd when pulling mountains in central PA, completely skipping 3rd gear. He was well within the weights, but it didn't like pulling up hills with that rear end and trans ratio. I'm sure Ram has fixed that with the new 8 speed, but read reviews just to be safe and make sure you get the right rear axle ratio.
Dec-17-2020 07:14 AM
wanderingaimlessly wrote:
If you are going Ram, since your now in Va you may want to check these guys, they usually seem to beat most of the Va dealers
Kernersville Ram
And they will still handle all the Va paperwork.
Happy hunting
Dec-17-2020 07:10 AM
Dec-17-2020 07:08 AM
Dec-17-2020 07:07 AM
Dec-17-2020 06:51 AM
colliehauler wrote:
Sounds like you could get by just fine with a gasser. It will have less performance towing. If I was you I would take a gasser out for a test drive and see if your happy with it. Only you can decide that.
Dec-17-2020 06:49 AM
Does your small town have a Ram dealership? Try calling for a service appointment to get an idea of wait times.
Either truck you mentioned can handle that load if properly equipped, especially in flat country like Florida, but do your trips take you into mountain country where you may want the oil burner? If not, or not often, I would look hard at the gasser.
