โAug-14-2014 12:09 PM
โAug-26-2014 04:03 PM
bmcewan wrote:You are correct to deduct about 100# from available payload to account for the weight of a WDH.
---This exercise shows me there's not much left for payload. If I understand this right, I have just 6350 - 5610 - 100 (WDH) = 640# left, which at 15% leaves just 4266# for the trailer. A more aggressive 10% gives me 6400#, but since I have pretty limited experience towing I'm inclined to err on the side of caution and stay near that 4300# figure.---
โAug-26-2014 03:43 PM
โAug-26-2014 08:30 AM
โAug-15-2014 06:11 PM
lawrosa wrote:I don't think he is all that wrong. He seems to have a pretty good grasp of towing weights.The OP states a limit of 5800# available for TT weight. As nice and capable as this TT is.... It is higher than his limit.
The op's limit is wrong IMO, and this is why he asked here in post #1...
And once we get his axle weights from the scales it will show exactly what he has for payload...
Not that he is neccesarily getting the Nash I show, It was only a suggestion. Because the tanks on those units are all at the rear or on/near the axles. This is why I suggest a rear bath.
Also most of the Nash tongue weights are around 10%. I suggest because of floor plan and weight.
And to demonstrate that he probably has enough truck I pull a similar camper with a chevy s10 with 2700 lbs axles GVWR 4900. Fully loaded I am 200lbs away from that 4900 @ 4700 lbs.
Thats myself, grill and three crates in the bed of truck.( I ride alone)
fully filled fridge and pantry , two cases poland spring water in closet, 6 aluminum chairs under dinestte, ( these are all on or at the rear of axles) full propane, and 4 totes of clothes under the bed. All tanks empty.
Additionally if you want to go by axles, as I do, my rear axle is 2200 with WD. 2700-2200 leaves me 500lbs to work with. As far as I know the DOT would allow me to go over my GVWR as long as I do not go over my axle rating...
Would or could I live in my camper full time??? Absolutly.. Just wish it was 4 season and had that one slide...LOL..
โAug-15-2014 06:05 PM
โAug-15-2014 03:01 PM
โAug-15-2014 02:45 PM
โAug-15-2014 12:42 PM
โAug-15-2014 11:41 AM
Any advice for full timing in something this light?
โAug-15-2014 11:35 AM
lawrosa wrote:The TT is NOT the limiting factor.That Nash has a dry weight of 5061# That only leaves a little over 700# for the "stuff" 400 of which will be taken up by water in he 50 gallon tank.
The nash is a 7000 ilb trailer.. 7000-5061 = 1939....
1939 - 400 lbs water = 1539... That a lot of stuff...;)
And lets say 100 ilbs goes to the rear wheels from the WD...
Lets say 1400 left...
โAug-15-2014 10:18 AM
โAug-15-2014 10:04 AM
IndyCamp wrote:
The OP said he wants to live a "minimalist" lifestyle so I'm not sure why people are suggesting a 3500 and a fifth wheel.
It is absolutely possible to full time in a smaller rig. It all depends on what kind of camper you are.
Only the OP can say how much space he needs.
โAug-15-2014 08:42 AM
โAug-15-2014 08:31 AM
bmcewan wrote:
I'm new to the TT world, looking for a 19-26' TT for the wife and I. We planning to semi-retire in 5 years, when we'll be late 40's, and live a minimalist lifestyle, try fulltiming and visit a lot of the national parks.
I've read a lot of threads on the viability of pulling with a half ton pickup, and what it seems to come down to on these trucks is a low payload weight. Since there is a lot of variability in half tons, here's what I have. A 2011 Ram 1500 Tradesman, with tow package, which gives me some nice-to-haves. My limiting factor appears to be payload. Here's my TV specs:
Class IV receiver hitch, 4 and 7 point harness.
V-8 Hemi, 390hp, 407lb-ft torque
Heavy duty oil cooler
Heavy duty transmission cooler
160 amp alternator
3.55 gear ratio
Multilink Rear coil springs
6350 GVW; 14000 GCW; 1440 max payload
Max trailer 8900lbs.
To improve towing capacity, will add:
* load balancing system
* integrated electronic trailer brake controller
* 1000# rear suspension airlift system
My problem is, between the wife and I and a full tank of 26g of fuel, plus 50# of extra gear, and subtracting the 150# of driver weight (boy I wish I was back at 150#!) we're left with payload of 870 pounds.
Dialing in the tongue weight at 15% of trailer weight, I'm looking at a limit of 5800 pounds.
Have I calculated this correctly? Any advice for fulltiming in something this light? I suspect the answer is "give up and buy a 3/4 ton truck." But would appreciate any help analyzing this and some advice on looking at the problem from people with more experience on this than I. Thanks!
