Have a Dually with an valve stem mounted TPMS?
CAJW
If you have a dual rear wheel truck with an aftermarket, valve stem mounted, TPMS (tire pressure monitor system) sensor, you probably already know that the batteries need changing periodically. As luck would have it, right after I got home from the tire shop, the alarm went off that I had a battery on an inside dual sensor that needed changing. I have a TST TPMS system and although I was glad that I asked the tire shop to mount the wheels with the stems at 12 & 6 o'clock positions for ease of access, I found that getting my allen wrench in that tight space to loosen/tighten the set screw was a pain. After trying long reach needle nose pliers and such, I came up with the following makeshift tool for job.
Needed:
1/4" nut driver
5/16" socket (1/4" drive)
6" long 1/4" drive extension
correct size allen wrench for your set screw, (this is put through the detent ball hole in the extension)
Here's a picture assembled before taping to secure the pieces.
Here's the set up taped to keep the pieces together.
Makes things a lot easier and I'm all about keeping my composure when doing tedious tasks such as trying to land a small allen wrench on a set screw that you can see, but not touch. Hope this helps someone else keep theirs as well.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
4 REPLIES 4
Slated4Greatnes
I had custom brass valvestems installed on the inners to protrude through the outer wheels so I can access the tpms. That tool looks good and probably works great!!
2004 WW SLC3505
Truma tankless WH, 6V's, LEDs inside/out, Flipped axles Michelin LTX's.
2006 F350 Tow Boss W/Training wheels
(Bulletproofed) ARP's, Decked blk/heads, BPD Remote OC, EGR & WP, Snow H20, 4.30:1, SCT W/GH, FS bags, 6" Aus Stax, Train Horns.
ksss
I went to transfer the rims and tires from my 2012 2500HD to the 2015 3500HD SRW, got down to having to deal with the TPMS and found out that the 3500's don't have it. I thought that was interesting.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Sport45
I don't use TPMS, but want to complement you on the thoughtful repurposing of tools. Good job!
โ€™19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
dbbls
I don't use the set screws to lock mine on. I have not lost one in over two year.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
