Hayes Sway Master Elec Sway Control. Does it really Work?
CamperMan78
I am new to the forum and have been towing a large pop up (2003 Coleman Niagra Elite) since 2013. I recently upgraded to a 2017 Jayco 28 foot Travel Trailer. Dry weight is about 6,000 lbs. I have been taking some practice runs with it and at about 60 to 65 mph (Dry) and I started to experience a little bit of sway. Shank and hitch are all installed properly by RV shop along with my Equalizer WD. I wanted to know if anyone on here has had any true experience with the Hayes Sway Master Electronic Sway Control and if it really works and if it will be beneficial to get one. Also will adding some sand bags to the front trunk to get me close to the 600 lbs (10%) tongue weight will help. I don't carry much gear so everything in the front storage area is about 100 lbs. Any advice is welcomed.
15 REPLIES 15
CamperMan78
No. It is aftermarket. The problem was with the integrated brake control on the GMCmodels from 2015 and up I think. Hayes says it was comparable. Plus I took it on a 20 mile round trip test run on I80 here in Illinois and has some cross winds of about 30 mph. She held up fine. Totally confident now for my memorial day weekend and 4th of July week.
afidel
Is there Quest brake controller the same module used in the current GM pickups? If so it is incompatible with the Hayes system (was very disappointed to find that out as the idea of basically ABS traction control for the trailer was very enticing to me)
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
CamperMan78
Thanks for the info. I already installed it on my A frame of my 2017 Jayco
28 ft TT. 6,000 pounds dry weight. TV is 2008 GMC Yukon Denali 6.2 Liter with K&N Cold Air Intake, Flowmaster Cat Back, upgraded Trans Cooler, NAPA Ultra Premium slotted Rotors and Premium Pads, Bully Dog GT tuner, Equalizer WDH, Quest Electronic Brake control. I am going on a 100 mile road trip to a campground for memorial day weekend. This will be the first true test. I will keep you posted and let you know what I think.
exploringcaroli
Installed a Hayes Sway-Master last year and it's working fine on my rig. The 23.5' Oliver travel trailer weighs in at 4950 pounds ready to camp with empty water tanks with 450 pounds tongue weight. TV is a 2016 5.7L Toyota Tundra without suspension modifications. Not using WDH.
After installation tested the Sway-Master at 55MPH and sway dampened in 1 1/2 oscillation. Towing in high gusting crosswinds on I40, TN plateau area at 60MPH, and sway dampened within 1 oscillation.
The Sway-Master uses a GPS to sense speed and operates above 45MPH. If GPS signal is lost, the Sway Master is active at all speeds.
Talk to Hayes to be sure sway master is compatible with your TV.
Bill
Oliver Elite II
5.7L Tundra 4X4
dodge_guy
By the time you are loaded for a trip you will be right around 7k lbs. you want to be at 12.5% for tongue weight (10% isn't enough!). That would put you around 875lbs. I know you came from a PuP, but you will be surprised what you take with you even if you don't think it's that much.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
camp-n-family
Check the hitch set-up again if the dealer did it. Many dealers don't spend the time to adjust it properly and when they do the trailers are not loaded up to camp.
You should have a minimum of 12 percent for tongue weight to be stable and reduce chances for sway.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
bobndot
Re-check your hitch set up, it was not performed correctly.
http://davidsrvtips.blogspot.com/2009/02/hitch-setup_2781.html
You need to have enough weight on your rear wheels while keeping your front wheels in check to allow steering control.
Just because the dealer did it does not mean it was done correctly.
A 2017 28 ft Jayco does not need sand bags.
As well as setting up my own and recently went through this with someone and a new Jayco already . I had them call the dealership from a rest area where they had to pull over. The dealer sent out a different mechanic who told him the hitch was not set up correctly. After a few adjustments, it towed like a dream. Not enough weight distribution on the rear wheels.
boosTT
Can you just fill the fresh water tank?
CamperMan78
Yeah you may be right. I am accumulating all the gear that I would need for this new travel trailer and then I'm going to head to the scale and then do a test run and then if I experience any sway, I'm going to head to Menards and pick up some of those sandbags and just make a whole entire day of it until I get it right. I went ahead and I bit the bullet and just bought the Hayes electronic sway control. It couldn't hurt and there are not many reviews on it the few that there is are very good. For a couple of hundred bucks it's a small investment for a little added peace of mind and safety.
budwich
oops... I didn't read the "get me close to 600"... then you need to add 400... ๐Ÿ™‚
I think your tongue is way to light but your strategy of incremental adds will likely find the solution. Your best bet is load up with your "normal gear" along with supplies (ie water, propane, cords, etc) and head to a scale and get a more accurate weight scenario and go from there.
CamperMan78
Actual weights. I am kind of a safety but so I have been taking this thing on test runs about twice a week before I commit to putting my family in the TV. The Equalizer WD with 4 point sway control works phenomenal but the Jayco has a lot of butt bebjnd thd tandem axles and sometimes catches a crosswind at 60 to 65 mph and i can feel it. Which is why I want to add weight in increments to get good balance in weight but also while leaving some room for our clothing and personal belonging like clothes etc. I was told that even with the equalizer weight distribution hitch setup that I would still experience a little bit of sway just because I'm towing a long travel trailer. I was hoping that the Hayes electronic sway control wood assist in eliminating some of that sway
TomG2
I like Jayco, but I am really disappointed that they would sell a trailer that needed hundreds of pounds of dead weight added to the tongue. Are you dealing with actual weights, or brochure bs?
Hannibal
It's been windy. Are you sure it's not just crosswinds? We saw a lot of different combos with different hitches coming home Saturday. They were all getting blown around as much as we were. Our 28RLS tows great without any sway control but we do feel wind gusts and cross winds when trucks pass.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
CamperMan78
I was thinking that I would add Sand Bags in small increments. Menards carries what's called "Sand in a tube" and they are 70 lbs each. I'll probably start out with 4 of them (280 lbs)
