heater Fan Run Time
jake2250
I searched but cannot find an answer,,
It seems that my heater fan comes on before the heater lights off. The fan runs for almost 40 seconds then you can hear the heater light off, when it reaches set temp you can hear the flame shut off but the fan continues to run for up to a minute!!
So it starts blowing cold air then ends by cooling everything off again.
My question: Can I adjust fan run time?
On our Pop Up trailer the little heater fan would come on for like ten seconds then the heater would light, then at temp set the flame would go out and fan would only run for about fifteen seconds..
17 REPLIES 17
WayneAt63044
It aggravates me too but that's how they work.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
FLY_4_FUN
ksg5000 nailed it....your system is working exactly like it needs to do, don't change a thing
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
ksg5000
Sounds like the heater is working fine. What's the issue? For safety reasons the blower is suppose to start first which lifts a "sail" which then tells the heater it OK to commence the ignition starting system. The fan is suppose to run for a while after the heater shuts down to cool down the system and maximize the heat value.
Kevin
