โSep-26-2018 11:52 AM
โOct-06-2018 05:54 AM
โOct-05-2018 08:09 PM
dodge guy wrote:
I have never seen an ST tire in a LR โEโ. Even a D would be hard to come by.
โOct-05-2018 08:07 PM
CALandLIN wrote:
LRD tires are 65 PSI tires, not 80. LRE is 80 PSI.
Make sure your wheels and valve stems are rated for 65 PSI and then air all tires to 65 PSI.
โOct-04-2018 11:34 PM
tewitt1949 wrote:
I had to replace my tires on out TT and it came with 12 ply tires. I wanted something heaver. I ended up going to a 14 ply tire that is used on trailers that are used to haul bull dozers etc. (construction equipment) They were only $20 more per tire than the 12 ply.
โOct-04-2018 07:09 PM
โSep-30-2018 07:44 AM
theoldwizard1 wrote:
Trailer tires are ALWAYS run at maximum pressure as listed on the sidewall !
โSep-30-2018 06:22 AM
JIMNLIN wrote:Atlee wrote:
Go look at the new Goodyear Endurance then. All of their tires start at LRD, even the 14".dodge guy wrote:
JMO but I took it dodge guy was referring to the 14" size tires in question.
โSep-30-2018 04:41 AM
โSep-29-2018 05:04 PM
fdwt994 wrote:
How can I check the pressure my rims are rated for?
โSep-28-2018 05:38 PM
โSep-28-2018 02:00 PM
spoon059 wrote:
Back on topic...
OP, when you get your tires changed, have them check the max PSI your rim is rated to handle. I bet your Load Range D tires are actually rated to 65, as 80 PSI is usually in LRE tires.
I'd think your 14" rim is rated to 65 PSI, and I would air them up that high. The stiffer your tires, the better your overall experience will be. They will flex less when traveling, making them stay cooler and last longer. You will also experience less sway with less flex in your tire.
โSep-28-2018 09:07 AM
โSep-28-2018 05:54 AM
โSep-28-2018 04:03 AM
