Aug-03-2023 12:04 PM
Aug-05-2023 10:32 PM
Aug-05-2023 07:03 PM
Aug-05-2023 06:56 PM
Aug-05-2023 06:46 PM
Aug-05-2023 06:41 PM
Aug-05-2023 10:16 AM
Aug-05-2023 09:14 AM
Aug-05-2023 05:46 AM
Miguel951 wrote:
Whoops missed there was already a page 2. Thank you all for the feedback
1) I hear your concern about having too much weight off the front axle. I cant say I can go the scales yet. For now, hoping the airbags will help to keep the stock riding height and weight shifted correctly and the weight-distributing hitch will also help push weight forward. I have all the right wheel and suspension upgrades to stay under limitations and it drives great right now. I will for sure keep this in mind.
2) I can see about using an 18" extension. its actually a 10' floor on what should go on an 8' bed I'm using a 6.75' bed. also carry 1 1/2" plywood sheet running from the length of the bed to help distribute weight better. There's not much weight on tailgate. but will also check this out.
Is a 2.5 hitch with a proper extenion recommended or the truss 2 hitch system? Is the second one overkill?
Aug-04-2023 09:42 PM
Aug-04-2023 06:44 PM
Aug-04-2023 01:14 PM
Aug-04-2023 12:58 PM
Aug-04-2023 09:06 AM
Miguel951 wrote:
I do need a 36" a little more or less would be fine. My camper is for an 8' bed and I have the 6.75 so the tailgate has to be down. The handle on the jack of the trailer could possibly hit if I go shorter.
Agree that its hard to find a 2" extenion but I did. One on Facebook marketplace that was custom-made by Eckhart and the other on E trailer https://www.etrailer.com/Hitch-Fabrication-Parts/CURT/C49360.html. Doesnt have nay ratings though.
I was told that i should go with the 2.5" because the 2" would break from the stress of the side-to-side motion. Thoughts and input would be appreciated
Aug-04-2023 08:57 AM
ticki2 wrote:
You have a short bed truck with a long bed camper , most likely taking weight off the front axle . Then in addition your putting a 3 ft extension and a 600 lb tongue weight off the back . It’s time to hit the scales , truck axle weights , truck and camper axle weight and if possible, truck camper and trailer axle weights . I suspect you are going to be too light on the front axle and overloaded on rear tires . A WDH will help , maybe enough maybe not . My humble opinion is there is more than one problem to solve .
Aug-04-2023 06:29 AM
