โJun-25-2021 05:20 AM
โJun-27-2021 07:56 AM
โJun-27-2021 05:43 AM
mkirsch wrote:You are wrong. You have it backwards
Helper springs and timbrens are full time support. Airbags can be easily adjusted for the load, or no load at all.
โJun-26-2021 12:22 PM
โJun-26-2021 11:45 AM
โJun-26-2021 10:31 AM
โJun-26-2021 10:30 AM
โJun-26-2021 09:49 AM
โJun-25-2021 12:55 PM
โJun-25-2021 11:17 AM
โJun-25-2021 10:59 AM
โJun-25-2021 10:41 AM
Itakethe5th2011 wrote:
If price is no object, air bags would be the best way to go. The problem with air bags, you will need a air compressor, a controller in the cab, (to adjust the bags hight) and the air bags with mounts. Then you have to hook it all up. I removed my bump stops and installed Timbren Suspension System. It took less than a hour to install. The bottom of the timber sits one inch above the axle so it will not change the ride of my truck. Once I load the 5th wheel, my truck squats a little over a inch. It is more stable side to side and no maintenance required.
โJun-25-2021 10:24 AM
โJun-25-2021 10:09 AM
C.B. wrote:Geo*Boy wrote:
I have had very good results with Timbrens. They make a kit, FR1504E, for your truck and you can remove the supplied spacer to adjust the ride.
Ditto:
Timbrens work great on my F-350. No messing around with air compressor.
C.B.
โJun-25-2021 09:48 AM
