โNov-03-2018 02:49 PM
โNov-04-2018 05:48 PM
โNov-04-2018 05:39 PM
โNov-04-2018 08:06 AM
โNov-04-2018 07:50 AM
zb39 wrote:
I am setting up the same system right now. 2019 Jeep 2 door is on order and I have the Roadmaster sterling tower from previous RV's. I will also be using chains to triangulate.
โNov-04-2018 06:08 AM
โNov-04-2018 05:54 AM
โNov-04-2018 03:29 AM
โNov-04-2018 03:15 AM
โNov-03-2018 11:29 PM
yblaw wrote:mike/kellie wrote:
I can only respond to the braking system. I bought the Ready Brute with surge. I bought a new Ready Brute tow bar from a member here, and then purchased the base plate and separate surge extension. I didn't want wiring going through the jeep. I have 2 cables mounted to the brake pedal through the firewall. One is emergency break aware and the other is surge cable. Brake, turn and tail lights are the magnetic type ( battery fed led ) secured to cargo basket over the spare, fed my transmitter plugged into the 7-way plug.
Great father's day present from my kids that performed perfectly last month.
Spider senses flashed seeing a single tube extension. Looking at my Torklift, 2 tubes fastened together with 3/8" chain turnbuckles.
X2 on Mike/Kellie's concern about a single tube. I think you will find that the Mammoth is 11 1/2' long, and that you need a minimum 42" hitch extension. I use a 48" Torklift truss system on my Mammoth to put a little more distance between what I'm towing and the back of the camper.....
โNov-03-2018 11:05 PM
โNov-03-2018 09:14 PM
โNov-03-2018 08:36 PM
โNov-03-2018 06:39 PM
โNov-03-2018 03:26 PM
โNov-03-2018 03:18 PM
