โOct-11-2016 02:59 PM
โOct-12-2016 05:53 PM
billyray50 wrote:
Thanks all.. Fixed the leak. Just had to tighten it with 2 wrenches.
โOct-12-2016 01:23 PM
โOct-12-2016 12:57 PM
โOct-12-2016 05:18 AM
โOct-12-2016 05:11 AM
โOct-11-2016 08:40 PM
midnightsadie wrote:pipe dope(thread sealer) wont work. Flare fittings work on compression of the flared copper tubing to the fitting. The nut and threads just compress the flare to fitting.
X 2 I,d put a little pipe dope on the threads before retightening,if it works? recheck for leaks a couple days later.
โOct-11-2016 07:49 PM
gregchambers wrote:I agree.
Any sealant (which technically shouldn't be needed but occasional is) should go between the internal tapered flare on the copper tubing and the external taper or "nose" on the brass fitting. I would avoid getting sealant on the threads as that could impede properly tightening of the flare nut. The threads don't seal on flare fittings, only where the tubing and fitting meet.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โOct-11-2016 04:24 PM
โOct-11-2016 04:20 PM
โOct-11-2016 03:25 PM
โOct-11-2016 03:14 PM
