How does Ford 6.2 (gas) do at altitude
diver110
I am not trying to restart the diesel/gas debate. I have been hearing a lot of good things about this engine. I go to Colorado a lot, often up around Ouray (8000+ feet), and was wondering how the truck would do up in that thinner air, especially with a camper on board.
10 REPLIES 10
jimh406
Gas engines of today are different with fuel injection compared to carbs of years past. I don't have one now, but the last one had no issues at altitude.
RZAR66
Did not notice any difference performance wise with my 6.2 in high altitudes. We went to Mesa Verde NP in Colorado. My rig tips the scales right around 10,400. We also saw temps at 119 plus going thru Needles, CA this past July and the coolant temp never rose above 215 degrees climbing hills.
2018 Ford F-350 DRW
2024 Northern Lite 10-2
rottidawg
My Chevy 6.0 pulls all the passes here in Colorado just fine with a 2,000 lb camper. I can easily maintain/exceed the speed limit on the I70 Eisenhower tunnel and Vail pass corridor. Your 6.2 will do just fine....these new gassers are great.
2012 Chevy 2500HD LTZ CCSB 4x4 gas
2012 Four Wheel Camper Hawk
2008 Harley Street Glide
dadwolf2
SeldomSeen has the Ford 6.2, lives in Flagstaff, AZ area @ 7500' elevation, and I believe really likes it. You could ask him for more detailed info.
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Mello_Mike
Not a problem at all. I've taken my truck and camper combo (about 10,200 lbs combined) up several passes and mountains the most notable being Boulder Mountain in S. Utah (9,600 ft) and Mount Graham in E. Arizona (9,300 ft). No sweat hauling or braking up major inclines, plus I'm able to easily pass 18-wheelers up major interstate passes with no problems whatsoever.
Review of the 2011 Ford F-250
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
brholt
In some configurations Ford gives the engine a 15,000 lb trailer rating. Even with the power loss due to altitude I don't think it will have much trouble with a 5,000 lb camper. I certainly haven't had any problems in the mountains.
1mtnman
Here you go this article from a user might answer some of your questions. Don't even think about a 3/4 ton or 2500HD series.
Lance855S
Here is the second part; SECONDPART
diver110
NEOK wrote:
Not sure if the camper on board means a truck camper or you are pulling a trailer. I have had our 6.0 gas GMC with our Bigfoot camper up in 9000 to 11000 feet altitudes with no problems. My camper may be smaller than your load.
I meant with a truck camper. I have been thinking in terms of an Artic Fox 811, Eagle Cap, or Lance 855S. That said, another thread indicated that you likely cannot take the camper off of the truck at sites in CA. Since that is where I planned to spend a lot of time, this is a big problem for me. It may make me think in terms of a pop-up and a lower center of gravity.
NEOK
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
WyoTraveler
Probably do ok with the 410 rear axle. None to drive and try out. Only special order. Otherwise I would have one.
