Aug-07-2013 05:01 PM
Aug-08-2013 12:37 PM
Aug-08-2013 09:45 AM
bikerdib wrote:
Do most of you use the plastic blocks sold at RV stores to level a rig?
Aug-08-2013 09:08 AM
Aug-08-2013 09:02 AM
fla-gypsy wrote:
Eyeball level will work
Aug-08-2013 07:01 AM
Aug-08-2013 06:52 AM
Aug-08-2013 06:31 AM
Aug-08-2013 05:36 AM
Aug-08-2013 04:29 AM
Aug-07-2013 10:29 PM
wnjj wrote:6pac wrote:
TC has to be level if using gas ref . If using AC voltage not so much...
The fridge doesn't care what the heat source is. It needs to be close to level on gas or AC. The reason is the coolant circulates by gravity through a spiral tube set. It can't flow uphill.
Aug-07-2013 08:20 PM
Aug-07-2013 08:17 PM
Aug-07-2013 07:57 PM
Aug-07-2013 07:03 PM
brholt wrote:
My manual says 6 degrees front to back (refrigerator front) and 3 degrees side to side. That is a pretty big range.
