โSep-02-2015 08:04 AM
โSep-12-2015 04:04 PM
72cougarxr7 wrote:stufarmer wrote:
As often as this subject has been questioned, I've never commented because 90% of the suggestions are relatively acceptable. So now, my 2$. I clean and repack the Wheel Bearings soon after ownership. If they're not Timken Bearings, I replace them. The Seals, if from China, they're tossed. I use Amsoil Synthetic W/B Grease. After that, it's at each brake inspection. That's usage based. Flat land Florida, or the Rockies & Sierras... Or immediately at any sign of grease on the front or back the Wheels.
Great suggestions! Using a quality bearing and seal and a great synthetic grease like Amsoil will certainly give you many trouble free miles.
Have you noticed when you pull the bearings on a fairly new trailer, it seems like the factory barely greases the bearings? Like they are rationing the grease and they have figured out .5 ounces of grease will get them out of warranty!
โSep-07-2015 06:36 AM
โSep-02-2015 07:26 PM
โSep-02-2015 06:10 PM
โSep-02-2015 06:00 PM
Lynnmor wrote:
I'm from PA as well. The only way to measure brake wear is to remove the hubs. The problem is some doofus will destroy all the hard work you did to get things right. The folks on here that don't pull their hubs and inspect is the reason we have these stupid inspection stations.
โSep-02-2015 05:54 PM
โSep-02-2015 05:50 PM
jfkmk wrote:
Mosseater, they actually remove the hub? What are they looking for?
โSep-02-2015 05:05 PM
mosseater wrote:
There are more bearings and seals ruined by mishandling than actual wear and tear, by a wide margin. Keep them clean, repacked, and properly adjusted and they will outlast you.
Here in PA where we have mandatory yearly inspections, each trip to the garage is an opportunity for mishandling, introduction of dirt, too tight or too loose, nicked seals, etc. I find it irritating and unnecessary, but the gubbermint says we have to. It isn't rocket surgery, but it still needs to be done properly.
โSep-02-2015 04:50 PM
โSep-02-2015 04:48 PM
โSep-02-2015 03:07 PM
โSep-02-2015 12:13 PM
โSep-02-2015 10:11 AM
โSep-02-2015 10:02 AM
TucsonJim wrote:
The reason they look "brand new" is that you are cleaning and repacking them. As long as you maintain them, there is no reason to expect them to wear out.
