how much weight can we have?
TraciK
Truck 2003 Dodge ram 2500 heavy duty 4x4
inside the door this is what it says
GVWR 8800
GAWR 5200 front 6000 rear
25 REPLIES 25
TraciK
It is a 4 door. Not sure if that's a quad. lol
Thanks for the help everyone!
I am waiting for more information on the tc.
ScottG
Assuming you have a similar truck to mine (quad cab) then you curb weight is about 7000 lbs and you have about 2000 lbs of capacity. My 3500 has 900 lbs more.
There's no way it weighs only 6K.
sue_t
Our 2002 F-250 PSD weighed in at 6966 lbs with two humans and two dogs, some tools in the supercab, fuel and our coffees.
Front axle was 4,232
Rear axle was 2,734
The 8' camper we purchased has a dry weight of 1,900 lbs.
Loaded for a trip I expect it weighs about 2,500 lbs. We haven't weighed it yet though.
Yup, I know ... we're over the truck's GVWR. Even so, the truck handles the weight well. We do a lot of off-road and gravel roads. Haven`t had any issues.
Interestingly the truck carries the camper better than it pulls our 25' fifth wheel. With just the fifth wheel the truck is under its GVWR by a couple hundred pounds. Burns less fuel with the camper than the fifth wheel too.
The truck manages the fifth wheel very nicely but it works harder with the fifth wheel, without a doubt.
sue t.
Pictures from our many RV Adventures to Yukon & Alaska from Vancouver Island. Now we live in Yukon!
bka0721
You are rounding a lot of things off, I would not do that but look at actual amounts and don't trust guessing/assumptions. It is sort of like guessing what is in your checking account, without doing the actual math.
A few things. You mentioned your truck is a 2003, what tires do you have on the truck? Often, the weakest link will be your tires and rims.
Next, actual weights of your truck would answer your question. Often we have new Truck Camper owners arrive here to ask questions to receive affirmation to their needs. If so you have arrived at the wrong place. This group wants you to be safe, as well others that travel on the roads that you travel on, as well.
Another important factor is your estimated personal stuff weights. The figure that has been the approved amount, after many years of discussion here, is a firm #1,000 lbs.
Also, don't go by what an individual tells you what the camper weighs, especially if they are selling the camper.
Don't believe the sticker on the side of the camper, as that is often not even close to what the Truck Camper actually weighs. Go weigh the camper, if available, or if your margins are close with the available carrying capacity of your truck. Having a comfortable/safe truck laden with a Truck Camper is a wonderful feeling.
So;
What are the actual numbers on the door pillar tag?
What is the weight of your truck, from a recent scale weight?
What is the camper you are looking at (most of us can get you a better idea what the expected wet weight of that camper will be)?
What is the cargo capacity of the current tires you have on your truck?
Do you have the OEM Rims on your truck? (If not what is the capacity of the current rims?)
By all means, have fun!
b
08 F550-4X4-CC-6.4L Dsl-206"WB GVWR17,950#
09 Lance 1191
1,560wSolar~10-6vGC2-1,160AmpH~Tri-Star-Two(2)60/MPPT~Xantrex 2000W
300wSolar~2-6vAGM-300AmpH~Tri-Star45/MPPT~Xantrex 1500W
16 BMW R1200GSW Adventure
16 KTM 500 EXC
06 Honda CRF450X
09 Haulmark Trlr
Rbertalotto
This thread might offer some insight:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27160562.cfm
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
12V_Cummins
I would stay around a 3,000lbs dry weight and no larger than a 9.5 length
johnrbd
I was always under the "assumption" that if your headlight did not interfere with airline traffic you were "good-to-go"!:h
But then, I always towed a 5th wheel trailer.
TucsonJim
The information you provided is from the placard that indicated GVWR, GAWR, etc. Down on the tire placard, it should tell you the max cargo and passenger weight you can carry along with what tires are specified and what the inflation amounts should be.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
sch911
There is no way a stock 2003 Ram HD weighs in at 6000#. You really need to have it weighed! When I had an 03 it weighed in at 7200# with the Cummins, full of fuel and no passengers.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
TraciK
I had put the KG in the first time went back and corrected it.
I think we have it figured out.
From what we can tell without weighing the truck is its curb weight is around 6000. So, we are thinking we can haul around 2800 pounds.
So, our max weight for a tc would be 2000. I'm thinking 800-1000 for extra weight. Does this sound about right?
I saw a tc that I really like and wouldn't mind going to look at but it weighs 2200. So, we would be over by 200 pounds give or take. How bad is that? lol
Jaxom
Take your truck to a certified scale and weigh it. That will tell you what you can put on the truck.
This looks right to me...2359 front 2722 rear.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
