โFeb-20-2020 10:44 AM
โFeb-21-2020 05:09 AM
FishOnOne wrote:
Here's a video from Headlight Revolution on installing LED lights. As you can see later in the video at around 3:47 the quality of the beam pattern is very similar to a standard bulb. If installed and adjusted properly the light quality is excellent while not blinding others.
Link
โFeb-21-2020 05:03 AM
โFeb-21-2020 04:29 AM
โFeb-21-2020 03:09 AM
โFeb-20-2020 11:45 PM
โFeb-20-2020 09:09 PM
Iraqvet05 wrote:
I'll continue to be that jack ass. I don't get flashed, I don't get pulled over (I imagine because 95 percent of LEOs don't know how to interpret the DOT law you provided). I see far brighter LED lights on factory vehicles that my cheap retrofit. Sorry, but you can't convince me that a halogen bulb that has very little directionality is that much different from an LED. Maybe the lumen output is more of a factor with the brightness than the design of the bulb.
โFeb-20-2020 05:32 PM
โFeb-20-2020 02:48 PM
Iraqvet05 wrote:ShinerBock wrote:Iraqvet05 wrote:ShinerBock wrote:
LED or HID in a housing made for halogen lights are illegal in all states, and enforcement is sporadic. If you want to put these kind of lights on your truck and stay legal then you would need to spend the coin and buy housing made for these types of bulbs(i.e. projectors) that do not scatter the beam.
I'd really like to read this law from a legitimate source, not "the internet said". I work for a police department...it's not enforced at all here. I've also traveled at night in Kansas, Colorado, South Dakota, Nebraska, and Arkansas and passed many police vehicles and I've haven't been pulled over.
As I said, enforcement is sporadic and most new officers do not even know it is illegal. As far as your state, somewhere in the transportation code it will state that a vehicle has to abide by Federal Motor Vehicle Safety Standard 49 CFR Part 571 which is what makes putting a HID or LED bulb in a housing made for halogen illegal. You can put an LED bulb in an LED housing or HID bulb in an HID housing, but neither in a halogen only housing.
CFR 49 571.108
Not to mention that it is a j@ckA$$ thing to do. I understand you need to see, but so do others on the road. I don't think they should be blinded just because someone is too cheap to do it right. If someone can afford a $40+k truck, then they can afford to spend the extra coin on the correct housing for the bulbs they want.
โFeb-20-2020 02:21 PM
jfkmk wrote:agesilaus wrote:
As a semi proof I've found that I can keep my headlights on high and drive around and have never ever been flashed by oncoming drivers..
Brilliant.
โFeb-20-2020 02:16 PM
โFeb-20-2020 02:13 PM
Iraqvet05 wrote:
.....and I had to turn my bucket adjusters down to keep from getting flashed all the time.
โFeb-20-2020 01:48 PM
CFR 49 571.108
โFeb-20-2020 01:11 PM
โFeb-20-2020 01:06 PM
