โSep-22-2014 05:14 PM
โSep-22-2014 08:46 PM
bka0721 wrote:
They appear to have been over torqued. Just because you can still crank on a nut, does not make it right. Thread stretch is an important part of the equation, thus the reason there are limits and requirements on Tolerances. I suspect the reason for the bolted U Clamp was/is to hold it in place. Have the installer go a little less on this with the impact wrench, as they are not the same tolerances as Wheel Studs. I have struggled many times to remove a lug nut because some monkey got a little nuts with the impact wrench. Thus creating a weak fatigue that over time fails.
b
โSep-22-2014 08:41 PM
โSep-22-2014 08:33 PM
โSep-22-2014 07:50 PM
โSep-22-2014 06:06 PM
โSep-22-2014 06:05 PM
poncho62 wrote:
I would not use a bolt like that...I would get plates put under the leaf with 2 holes to match the top holes and grade 8 bolts...Much stronger in my mind
โSep-22-2014 06:01 PM
โSep-22-2014 05:46 PM
โSep-22-2014 05:28 PM
