Oct-10-2013 04:48 PM
Oct-24-2013 06:30 AM
Oct-23-2013 09:57 PM
Oct-22-2013 11:07 PM
Oct-21-2013 08:38 PM
Oct-21-2013 08:35 PM
Oct-21-2013 02:35 PM
Oct-21-2013 02:34 PM
Jarlaxle wrote:
It would probably be easier (and would certainly finish with a more-reliable vehicle) to do a Cummins swap.
Oct-19-2013 07:01 PM
Oct-17-2013 08:28 AM
Oct-14-2013 08:44 PM
Oct-14-2013 08:28 PM
Oct-14-2013 05:43 PM
Oct-14-2013 11:51 AM
Oct-14-2013 04:28 AM
Lessmore wrote:Because Ford left the 6.0 owners to fend for themselves, they did have plenty of money for Mike Rowe. I bought a new 04 thinking it would last for several hundred thousand miles (like the 7.3). I will spend the money to (bulletproof) but will look at the track record for any new Diesel purchase. Ford is not alone when it comes to dumping a problem on the customer. My 1990 chev had the paint fall off, my 97 blazer had to have a motor(thanks dexicool). My 1998 Dodge had to have the front end, transmission and new ring and pinnion rebuilt before 100K. I had to pick up the tab on all of those. My 2000 X and my 99 F-250 7.3 have 160k and 250k miles and run great.jevanb wrote:
A built 6.0 is a great motor,if the problems areas are taken care of. lots of HP potential at a very cheap price
I always wondered why Ford didn't take care of the problems and 'bulletproof' the 6.0 at the factory...to begin with ?
I know the 7.3 liter PSD was a wonderful engine. A neighbour used to be a utility lineman and his service truck was an F 350, 7.3 diesel, 5 speed standard, DRW.
When he retired it had 400,000 on the odometer and he noted that it was still running well and being used as a regular service truck to years later.
Oct-13-2013 11:18 PM
vacuumbed wrote:Pull the glow plugs and then try to crank it. If it turns over you're golden. If not, you have a $13,000 boat anchor. My engine had a failed EGR cooler,and I knew if I did not get it back home soon I could do more damage. It hydrolocked when I tried restarting it, puling the glow plugs identified the affected cylinder. If you are lifting the house and putting it on the ambulance frame, you will have a much easier time than trying to swap the engine, all the wiring, fuel tank and fuel lines, and upgraded suspension parts. The 6.0 in the E-series did not get the "tune" from the factory that was the Achille's heel of the F-series truck.
Well, I just pulled the trigger on a 2008 E450, got it for $1,000! It's super clean. I will post pics soon. It will make a great donor vehicle, it has the newer front clip.
There's just a slight problem. The 6.0 PSD is seized up. :E
It's probably hydro locked from a failed EGR cooler, and the engine is going to come out anyway. I'm excited to get started on this!
