If you own a Ford pickup and live in the rust belt
ib516
You might want to watch this video.
Ford Pickup Problem
He never does say what "model" of Ford pickup he's talking about, but to me it looks like an F150?
Easy DIY fix to prevent the problem.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
10 REPLIES 10
nipster
That's a known issue for quite a while. There is an aftermarket one that is plastic, and sometime around 2007, Ford redesigned the part so it is lifted up off the frame rail so it wont rust
mosseater
Just checked mine today, and it's FUBAR. I'm going to get one ASAP. It's part of my "good for another 100K" program. Rock Auto doesn't have a Motorcraft unit in stock. Anybody know if the aftermarket units are good to go?
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
K_Charles
Whatchaupto wrote:
How does a person go about replacing "the rear half of the frame"? Do you remove the bed and everything attached to it (bumper, wiring, fuel tank, hitch, rear bumper, etc.), cut the frame apart at the factory welds (if there are any 1/2 way back), grind the cut areas smooth, weld the 'new' frame section in place and then hope it is all aligned correctly? I just can't wrap my brain around this process. Don
For many years ford pickups were made with a two piece frame riveted to gether at the front hanger of the rear spring. You cut the rivets and bolt it back together.
Whatchaupto
'12 Ram 2500 6.7L Reg Cab
'17 Northwood 246RKS
'73 Honda CT90
'11 Polaris RZR
'03 Jeep Wrangler
mhsmith
That was one of the first things I checked on my '12. The whole unit is plastic now. While I was there I applied some electrical grease to the connector. Corrosion in the connector is another problem I see around here. I also encourage my customers to wash their vehicles at least once a month during the winter. The stuff they put on our roads here is corrosive and causes problems over time-electrical and frame/body corrosion.
_DJ_1
Thanks for posting this. I have an F 250 gasser but will still check it out as those weather conditions are prevalent here.
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
dodge_guy
Yes we replace these a lot. The truck will either not accelerate due to low fuel pressure or like he said, not run at all. I would just replace it as a maintenance item. Around 80k or so. I think expeditions may have the same relay/driver also?
Thanks for posting this for the late model (04 and up) F150 owners! It is a definite must check/do!!!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
mosseater
Thanks for the reminder. It's on the list!
Sunset Creek 298 BH
Greg_B
I believe it's with the 04 and newer 1/2 tons. I read about the problem last summer on a Ford truck forum. Pulled the one out of my 04 1/2 ton and it looked like the one in the video. Another winters worth of salty roads and mine would have corroded completely through.
04 Dodge 1 ton dually, Cummins, auto, quad cab, 4x4, SLT, Sport, Reese Titan V
04 Lance 1161, TV/DVD, high efficiency A/C, Honda EU2000
K_Charles
I have a '97 F150 with about 198,000 miles and the only thing I have ever replaced is radiator hoses, alt, belt, battery, plugs and the rear half of the frame because it was rusted completely in half. It took me a long time to find one in a junk yard that wasn't just as bad as mine.
