Inverter install on a wolf creek
anutami
anyone installed an inverter on a wolf creek? I am trying to find a location, but there is not much room anywhere close enough to my batteries.
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
18 REPLIES 18
mkirsch
Nomad II
Nomad II
Those 12V blow dryers, heck, any of those 12V appliances that involve HEAT, are complete wastes of money.
Sure it only draws 14A. That's 168 Watts at 12 Volts. It would be more effective if you blew on her head with your nostrils to dry her hair.
If she absolutely has to have a hair dryer the only practical way in your case is to run the generator. You don't have room for an inverter, let alone the batteries it would take to run a usable dryer without completely discharging your battery bank.
Carb_Cleaner
Here's my install, on the side of the battery box. I still haven't put in the transfer switch or remote. One day. I've been busy with our new house and all the moving, painting, hardwood floors, 2nd laundry room, wall removal, new kitchen, yard renovation, etc., for the past while. I haven't checked in to RV.net for a spell. Hope you're doing well.
Wolf Creek 850 Inverter Install
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27872521/gotomsg/27875048.cfm
EDIT: I think a gal with long, wet hair is sexy.
'13 F250XL SC gas 4x4 8', Camper & Plow packages, StableLoads, LT285/65R-18 Goodyear Wrangler A/T Adventure, 18x9 Ultra Motorsports "Phantom" wheels
'12 Wolf Creek 850 TC Coleman Polar Cub 9.2k A/C, 90 watt solar, dual propane & batteries, Maggie Rack
towpro
wow, Just realized it will take most of what my honda 2000 produces just to run a hair dryer.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
corvettekent
anutami wrote:
I am looking to mainly run a hair dryer for my wife, so right now looking at the xantrex prosine 1000watt. What is the smallest watt hair dryer you can get. Would love to go 300 watt morninstart but don't think it has wnough juice. Not sure if I can get away with putting it under the sink or out of sight due to it needing air to breath. I like the idea of putting inside mounted to the battery box like towpro mentioned. Pretty sure the 850 and 840 are similar. I think I have enough room but worry about proper ventilation. towpro what inverter are you looking at putting in?
Thanks
Nolan
You are going to need a 2,000 watt inverter with at least 4 batteries to run a hair drier that you wife will like.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
joeshmoe
towpro wrote:
Nolan, search internet on 12v hair dryer. camping world has one, uses 14amp for $17.00 :). unless you need the AC for something else you can't beat that price.
I bought that one for my wife off Amazon a couple years ago. She's tried several 12V dryers. The one thing none of them do is produce enough heat. They all suck. AND that Roadpro pulls about 15A. Low wattage, but relatively high amp draw= still wet hair, diminished batteries and an unhappy wife (not necessarily in that order). Don't waste your money. Her hair is long and thick. Even with a regular, A/C powered dryer, depending on the humidity, it takes her at least 20 mins. to fully dry it.
Believe me, I've been holding off installing an inverter for the exact same reason. She groans about it every time we use the camper. For the time being, I have to fire up the generator. When that's not possible, she turns on the furnace, sits on the step, leans over and uses the ducts below the frig. Works pretty good and it's quick, but obviously, not ideal...for her. I have no problem with it.:B
I may install an inverter anyway just to have it.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
towpro
Thanks
Nolan
2022 Ford F150
towpro
Thanks
Nolan
I haven't gotten that far yet. I have one that I have been using under the seat of my truck to run Laptops, I will try it first to see if its enough power so I know where to start (still need the power in my truck for laptops).
My TV is 12V, so all I need to run is the Sat receiver and hopefully the Pathway X2 Dish I been waiting to afford.
2022 Ford F150
Camper_Jeff___K
Nomad III
Nomad III
I would mount the inverter as close to the batteries as possible keeping the wires short and properly fusing for the gauge of wire you use or smaller. Isn't there a propane hair dryer available?
joeshmoe
Okay, just read you want it for a hair dryer. That will require at 800-1500 watts. According to my wife, the small dryers don't work all that great. She has a lot of hair and has tried a lot of dryers. With her current Conair on the "warm" setting, I know it pulls about 800 watts. On high, over 1700 watts.
With that much demand, I think your only choice is to mount it near the battery box, in order to keep the cables short near the batteries. The basement fan could be wired to a manual switch for ventilation. Not sure how much or little air that small fan moves. Probably not a lot. Maybe look at upgrading to a higher CFM.
Rancho 9000's
joeshmoe
Hey Nolan,
I "installed" a 400 watt inverter up in the charging center cabinet and plugged into the 12V outlet. Really, it's the only accessible place I could come up with to keep it portable and without running extra cable. Unfortunately, the 850's battery box is not much of an option, IMO. Totally out of the way, unlike the 840.
For the few A/C items I run in the camper, it works good enough.
The other place I considered.
Rancho 9000's
anutami
Thanks
Nolan
time2roll
Any space around behind the breaker panel?
For 150 or 300 watts just use the main battery feed. Connect to the 120v circuit of choice with a small transfer switch. No pulling wire, just make connections.
Vinsil
towpro wrote:
I think there is enough room on top of my battery box, under the sink to mount mine. Might even use Velcro, or just 2 bolts up through the battery box with nuts on top. Still waiting for spring.
I am debating how i want to deal with the AC side. Currently my sat receiver is in the over head cabinet sideways held to back if wire compartment side inside cabinet with velcro strap, and it is sharing the AC outlet for the microwave. I am thinking of just running a new outlet for sat receiver, with a 2 way switch somewhere under sink to switch from sure power to inventor power.
There is, but we have 840's and Nolan has an 850, I'm not sure where his batteries are.
2017 Ford F-350, crewcab, 4x4, 6.7 diesel.
2016 Thunderjet Luxor 21' limited edition, Yamaha powered.
2016 Wolf Creek 840-SOLD, Arctic Fox 990 ordered.
towpro
2022 Ford F150
