Nov-03-2021 09:05 AM
Nov-05-2021 03:41 PM
Cummins12V98 wrote:
Don't think the above applies to the RAM. Anyone know for a fact?
Nov-05-2021 02:58 PM
Nov-05-2021 12:49 PM
ford truck guy wrote:Grit dog wrote:Jim-Linda wrote:
Have EB on Cat in FL60. Rig is 25 years old. It has BD exhaust brake that is turned off only on downhills in rolling country, EB will engage when not needed. The only drawback I can see is in city type traffic when EB engages, following vehicles are not aware of truck slowing due to no Brake light. No failures, original disk pads.
But it is a nice feature to get tailgators to back off!
Separate note, I've never checked, but the newer OEM integrated exhaust brakes, do they activate the brake lights when they kick in?
Under the right conditions one can scrub some speed pretty quickly without touching the service brakes.
I looked behind the truck when hooked to the fiver during the last night tow and did NOT see any brake lights on the truck... I can see them light up the front of the fiver compartment door.
That is always my concern as well... I kind of like my rear cap in 1, solid piece
Nov-05-2021 09:40 AM
riltri wrote:
I ran mine at all times for 3-4 months then noticed that my fuel economy went down around 2.5 mpg. Now it's only on when towing for going down a mountain.
Nov-05-2021 08:48 AM
Nov-05-2021 04:26 AM
Grit dog wrote:JRscooby wrote:
Every time I see a discussion about exhaust brakes I have to wonder if there has ever been a comparison of the whoa power of like sized diesel w EB/gas with closed throttle. (I know I nearly died the first time I expected a 855 CID Cummins without Jake to hold me back as much as 427 GMC did)
Unless it can be shown the exhaust brake ******* a lot more than the throttle plate, slick roads with it on would be no more dangerous than gas engine.
Idk about any of the GM L5Ps or the newer Powerstrokes, and it feels like you’re just fishing for a response to reply to about how these “little” pickups aren’t “real” trucks like you the pro truck driver, drive.
But I can assure you that both the aftermarket in-line brake I put on our old truck and the turbo brakes on the newer Rams have significantly more whoa power than any of my gassers, even the 10 speed that drops 3 or 4 gears when descending a hill with a trailer pushing it down the hill.
Cummins12V98 wrote:
UH YEA, I towed 34k combined with my 15 down several miles 14% grade locked in 2nd gear not touching my brakes. I thinks me EB works just fine!!!
Nov-04-2021 05:13 PM
dedmiston wrote:Lwiddis wrote:
But if it turns on automatically, you’ll forget to turn it off. That’s dangerous.
No it isn't. You don't forget to turn on your headlights, turn on your wipers, and roll up your windows.
There's a difference between risk and danger.
Nov-04-2021 02:33 PM
ford truck guy wrote:Cummins12V98 wrote:ford truck guy wrote:NamMedevac 70 wrote:
Are they loud Jo like the 18 wheelers. I do see signs everywhere. This from a newbie.
NO, you cant hear them , the only way to know you have one engaged is feeling it slow you down......
Are you sure you have one? I can hear mine, maybe that’s why it works so well. 😉
Perhaps "IF" I turned down XM-350 to a lower decibel I would in fact hear it ! :B
Nov-04-2021 02:31 PM
Nov-04-2021 02:22 PM
Nov-04-2021 01:52 PM
Nov-04-2021 01:09 PM
Nov-04-2021 11:40 AM
Nov-04-2021 11:36 AM
fj12ryder wrote:
The only thing I've noticed is that the EGT's are higher at idle with the engine brake on than they are with the brake off. I usually allow the EGT to hit 300° or below, before I shut the engine down, but with the engine brake on it won't go below about 350°.
Nov-04-2021 11:04 AM
