Jul-18-2014 06:22 AM
Jul-19-2014 01:29 PM
Jul-19-2014 12:55 PM
easycamper wrote:Fast Mopar wrote:
All minivans are miraculously rated for 3500 lb max, which cannot be true.
I agree. I also don't see how a small SUV like a 2014 Ford Escape with curb weight of 3600 lbs and a 106" WB is equal in capability to a Sienna which is 4400 lbs and 119".
Automakers are motivated to test trucks to their maximum potential because towing capacities are a marketing tool.
I would imagine for something like a Sienna, they just pick 3500 lbs and test to that, rather than pushing the limits to see what the vehicle is truly capable of.
So, I don't believe that J2807 has done anything for vehicles other than trucks.
Jul-18-2014 05:32 PM
Jul-18-2014 03:11 PM
Ron3rd wrote:
Didn't mean to imply I don't understand it, it's just meaningless to me as I use other criteria.
Jul-18-2014 01:15 PM
easycamper wrote:Ron3rd wrote:
I have a Tundra and don't even know what SAE J2807 is. I just look at the payload rating, gross rear axle rating, GCWR, etc, and take it from their. "Tow Ratings" are meaningless to me.
SAE Standard J2807: Performance Requirements for Determining Tow-Vehicle Gross Combination Weight Rating and Trailer Weight Rating.
http://standards.sae.org/j2807_201205/
It's supposed to be used to determine GCWR. Too bad it's applied so unevenly.
Jul-18-2014 01:09 PM
Jul-18-2014 01:07 PM
APT wrote:
I said drivers, not RV towing drivers. And still, even among naturally aspirated gas engine owners, WOT is uncommon. 5000rpm+ on a "big V8" scares many people. 🙂
Jul-18-2014 12:19 PM
Jul-18-2014 12:00 PM
easycamper wrote:
As far as I know, only Toyota and Ford currently apply the SAE J2807 standard to rate towing capacity of vehicles that aren’t trucks.
What do you think? Can we believe these numbers? I would like to think so, since the standard is being used.
I’ll take the current Ford Escape as an example. The earlier generations of the Escape were, I believe, generally considered less capable as an RV tow vehicle than their 3500-lb rating suggested. The 2013-14 model with the 2.0L EcoBoost engine is rated at 3500 lbs using J2807.
Jul-18-2014 11:39 AM
Jul-18-2014 10:11 AM
45Ricochet wrote:goducks10 wrote:
With 340HP and 800TQ my pedal never sees the floor:)
LOL I was thinking the same thing.
Might I suggest that 5% comment be something like " less than 5% of diesel RV pullers run WOT and a much higher percent with a gasser run WOT" :W
Jul-18-2014 10:07 AM
Jul-18-2014 09:37 AM
Jul-18-2014 09:32 AM
