โApr-11-2022 03:47 PM
โApr-16-2022 06:40 PM
โApr-16-2022 07:42 AM
โApr-16-2022 05:16 AM
โApr-15-2022 06:48 PM
JoeChiOhki wrote:
It may be a good time to put a stable lift on that unit, it was designed for underwing loading and unless you rebuilt the frame to properly carry the load along the truss, you have face issues again.
A stablelift would be similar to how it was originally setup for jacks and you wouldn't have to worry about it tipping over a second time.
โApr-15-2022 05:55 PM
CB
Channel 17Redneck Express
โApr-15-2022 05:23 PM
โApr-15-2022 05:22 PM
โApr-15-2022 03:37 PM
โApr-15-2022 02:14 PM
โApr-15-2022 12:11 PM
โApr-15-2022 08:10 AM
mkirsch wrote:StirCrazy wrote:BurbMan wrote:JRscooby wrote:
Unless on level surface, 3 legs is more stable than 4.
Re-read what he said. Hence the reason cameras use tripods, milking stools have 3 legs, etc. Obviously more legs provide more support, but the more legs you have the harder it is to load them all equally. Three legs means each has to carry more weight, but they distribute that weight much easier.
there easier to level and tram with three legs but not more stable, cameras use a tri pod because it would take for ever to get level if you had 4 legs, thankfully we dont need that kinda of persision with our campers
Not necessarily level, but to get it to sit without rocking.
A 3-legged stool will sit stably on just about any surface, but a 4-legged stool will rock on two legs unless you find just the right spot.
Since a camper's legs are independently adjustable, the point is moot.
โApr-15-2022 06:35 AM
JimK-NY wrote:
I think you are close to a solution. That angle bracket looks good especially if you include some structural steel from one side of the camper to the other. You could also consider extending that metal plate higher on the side of the camper, maybe even a foot or so higher than the jacks on the wall of the camper. The more, the better.
The angle iron will strengthen the side-to-side support, but perhaps you also need more support for the jacks and brackets in the front to back direction. Maybe another angle iron welded on at right angles to the one you are planning to use. Even better perhaps 2 pieces of steel going front to back. One piece should be toward the top of the bracket and the other as low as possible.
Perhaps I have not described this well. What I envision is a cradle under the camper so the lifting is on the cradle not on the attachments to the camper.
โApr-15-2022 06:12 AM
โApr-15-2022 03:43 AM
โApr-14-2022 07:00 PM
