May-07-2020 11:39 AM
May-08-2020 05:18 AM
Guy Roan wrote:
Under the "U" shackle that holds the axle is the correct way.
Never the frame!
Guy
May-08-2020 05:17 AM
May-08-2020 04:38 AM
Lwiddis wrote:
“Now having said that I did bend a frame on a fully loaded 38'..”
Interesting. Do as I say, not as I did?
May-08-2020 03:30 AM
May-07-2020 09:01 PM
wopachop wrote:ssthrd wrote:Nah dont even hook up the truck if thats what youre doing. Jack up one side at a time and do what you need to do.
For now, I am only doing maintenance--repack bearings and have a look at/adjust brakes, so I will be hooked up but no WDH.
May-07-2020 07:50 PM
May-07-2020 06:56 PM
May-07-2020 06:14 PM
Mike134 wrote:naturist wrote:
I've had a couple flats on a tandem axle trailer. Fastest/easiest/safest way to do it is put leveling blocks down, run the good tire up on the blocks high enough to raise the blown tire off the ground.
Don't forget to remove the WDH bars before driving up. They shift weight to both trailer axles and front truck axle
May-07-2020 06:05 PM
May-07-2020 05:42 PM
ssthrd wrote:
I have read and heard that you should never jack a travel trailer using the frame, the axle, or any suspension part. Kinda eliminates all options as far as I can see, other than rolling one tire up a ramp to raise the other one off the ground.
I have a Wilderness 2750RL. Are the frames on these things too flimsy to be used as jacking points? I would hate to jack the thing up and have the frame fold up on me.
Any real world opinions based on experience?
May-07-2020 05:32 PM
May-07-2020 02:47 PM
May-07-2020 01:42 PM
May-07-2020 01:40 PM
