jacking up tt
thoms
first off thanks for all the info on buying tires. got 4 carlisels coming.
What is the best way to change all 4? Jack up one side at a time using jacks and jack stands or doing both front first and then the rears??
Or any other ideas?
thanks again!!!
17 REPLIES 17
GrandpaKip
I use a Trailer-Aid like the photo above. I have 2 sets of Dexstar wheels, so I can just take 1 set to the tire dealer, then change them out. I got rid of the fancy aluminum wheels.
Last time, it took less than an hour to change out all 4.
And I got rid of the clad lug nuts and got solid ones.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
myredracer
I put a 2x4 block under the U-bolts and use a stubby bottle jack under that. That way the trailer doesn't tilt anywhere near as much compared to jacking up the frame. If you jack one side up, whether it's 1 or 2 wheels, make sure to use jack stands for safety and in case the jack doesn't hold and also make dang sure the wheels on the opposite side are properly chocked. You might also want to put the stab jacks down. If you lift the frame up, jacks need to be as close as you can to the wheel so you don't damage the frame.
You can easily take one wheel off at a time using a tire ramp or your leveling blocks. Taking one tire at a time to a shop could be a slow PITA, especially if you have to go any distance. Good method for changing a flat on the side of a road somewhere.
Easier way is to just take it into a tire shop and let them take care of getting the wheels off the ground. Some shops might put it on a hoist and get all wheels off at once. If aluminum rims, don't let a shop use an impact gun because they can over-torque the bolts. Torque the bolts up yourself to the specified torque (typically 90 - 100 ft/lbs but can be higher.) and check the torque at the intervals as per your owners manual.
Goin' camping this weekend for 1st time this year. I'm all jacked up! ๐Ÿ™‚
Ron3rd
downtheroad wrote:
I called Northwood (Arctic Fox) directly.
Their very strong recommendation: Never jack on the axle or spring hangers.....jack on the frame.
But...so that we don't get into a back and forth over this, I say do what works for you.
X2, that's the philosophy I go with. I figure the frame is the strongest link so that's what I use.
Equilizer Hitch
Honda EU2000
Ron3rd
Lots of good info above. I do one side at at time.
Equilizer Hitch
Honda EU2000
lgblau
I did t realize that small TT โ€˜s were so complicated. So, What would be the best way to jack my R-Pod 179.
JIMNLIN
I've had a 12t shorty hyd jack that cradles the axle tube next to the U bolt or it also has a adapter that cradles the U bolt.
Axle tubes on Leaf spring suspensions have a thick wall and will not crush or dent/bend next to the U bolts. Torsion axles have a thin wall
When replacing tires on my trailers like others I jack one side at a time and let the axle down on RR tie blocks under the U bolts.
Most of the time I take the trailer in and let the tire dealer do their thing.
Both of my tire dealers are set up to handle trailers of all types.
Bob_E_
On our camper, the axles are above the leaf springs. So I can put a jack and a block of wood under the tie plate below the spring directly under the axle. I do one axle at a time, one side at a time.
If the axles were flipped and located under the leaf springs, I'd use a block of wood under the axle between the u-bolts and jack from there. If the axle wall can support the weight of the camper under the vary small surface area of the spring perch, it should be able to rest on a block of wood between the u-bolts. If it makes you feel better, cut the wood block with a radius so it makes a cradle to spread the load. The other option would be to have the wood block under the u-bolts, spanning between the two. This would simulate the same loads on the axle tube as if the axle were mounted above the axle and secured with u-bolts.
DavidP
I change one side at a time. Remove both wheels from one side and have new tires mounted and balanced then on the the other side. Like in the picture from another member I also hook my tow vehicle to the trailer. My set up has torsion axles so I lift from the mounting bracket bolted to the frame that the axle is bolted to.
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
bobndot
Be careful you don't bend something that's thin walled like a spring hanger. I would jack it as is done in the link here or the frame itself. It seems like the more solid the metal, the more solid the lift will be.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24796694.cfm
mobeewan
crazyro wrote:
What is the best spot you recommend jacking up trailer? Axle close to wheel? Frame? (sorry for the thread hijack)
Never jack using the axle on a trailer. The tubing is thin unlike the cast ones on a car or truck.
I use a bottle jack with a piece of 2x4 on top under the frame next to a spring shackle for one tire. If both tires I do the same as for one then place a jack stands and move the bottle jack next to the other spring shackle.
I never place the jack under the pivoting link for the springs between the tires.
DutchmenSport
Like this:
old_guy
be careful you don't twist the frame. do one side then the other
samsontdog
I made apt with Discount Tires for 30 min before they opened and had me back the TT near the work area and had 4 workers come in early and had me out with all 4 tires mounted, balanced etc before 8AM
samsontdog:o:W
