Load Range E tire pressure: how do you keep them up?
Whangler
Soon, I will have my newer trailer, a 2014 Arctic Fox 25r. The first thing I do will be to take it to Discount Tire and remove the GYM's and put on LRE Maxxis 8008's.
My old trailer ran 14" LRC tires inflated to 50psi max. Even getting those up to pressure was sometimes difficult if I had to air up on the road using lousy gas station air. They held pressure very well, but once or twice I needed to bring them up a few lbs.
Now, these new LRE's run at 80psi. I reckon truck stop compressors will do the job but like gas stations, they're not always easily accessible. Do any of y'all use 12v tankless compressors when you're afield? If so, I'd like a recommendation for a good one. IF, that is you think it necessary.
Thanks,
Mars
31 REPLIES 31
goducks10
2012Coleman wrote:
Mandalay Parr wrote:
I fill my once a year. A few pounds over so they last for a year.
Never have to add inbetween.
Weigh your trailer then go by the tire chart for the correct amount.
80 may be too high.???
I'm finding this hard to believe. I air up my Maxxis 8008 tires using my air compressor. I check them every 3-4 weeks, and they are always 5-10 lbs low.
I hate to say this but my GYMs hold air all year as well. Better mounting job? All I know is that during the summer when I check them they don't need air. After sitting all winter from Nov 1st to around April 15th or so they only drop 3-4lbs.
I'm actually quite surprised by this, so I can see why you would think what you do. I would've never figured it either.
fla-gypsy
I fill my Maxxis tires with my compressor at home and they hold pressure for months without loss.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
gmw_photos
I've got one of those pancake compressors from hazard fraught that I bought for my air powered brad nailer, and I've used it to air up the 80 psi LRE tires. It worked fine. For the money those are ok comprsessors, although the optional extended warranty is a good idea.... you'll probably need it. I did....the first one died in a few months.
MarkTwain
Losing air Pressure----
Make sure you add metal stems to your rims before you put your new tires on. I run GY "G" rated tires @ 110lbs. I will loose 1 to 2 lbs. of air in a years time. Rubber stems tend to leak and then rot in time causing your tires to loose air.
Whangler
Thanks everybody. My last maxxis's didn't lose much, just down 1-2psi from 50 every 6 months or so. That said, my cheapo harbor freight 3 gallon compressor doesn't exactly make short work of topping them off. I can't imagine how it would labor to get from 77-80psi :-0
Rather than getting a dc compressor, maybe I'll just get a stronger one for home and keep my fingers crossed I don't need to air up afield.
LarryJM
As others have mentioned you have something SERIOUSLY WRONG ... that is way too much loss in such a short time. Maybe a lb or possibly two, but more than that NO WAY.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
dodge_guy
I only need to add air in the spring, about 10 psi.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dave54
carringb wrote:
Normal pressure loss is bout 1 psi per month. Maybe two in the fall as average temps drop. Anything more than that you are probably leaking at the valve stems.
I do not even get that much. I seem to lose about 1 psi per year on all my vehicles. I think the old rule of thumb is no longer valid. Rubber chemistry and tire construction must have improved to the point there is very little air loss anymore.
So many campsites, so little time...
carringb
2014 ORV really big trailer
2015 Ford Focus ST
midnightsadie
2012 colemen, I think you got leaks. thats way to much loss.
Lynnmor
Good tires will hold air, what can I say?
coolbreeze01
I air the truck and trailer tires in the spring. Although I have 12v pumps with me, they haven't been needed.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
2012Coleman
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
BB_TX
I carry a 12v compressor, but it takes forever to add much air. I also carry a Harbor Freight pancake 100 psi compressor ($39.95 on sale). Not very high cfm, but works fine for adding air.
But about the only time I ever add air is at the beginning of each new season. Usually add 2-4 lbs and am good the rest of the year on my Michelins.
azrving
I use my Honda 3000 generator which is mounted in the truck bed along with an oil less cheapo air compressor and 50 ft hose.
